Liquids - Critical Pressure Ratios
Critical pressure ratios for water:
Critical pressure ratios for liquids other than water:
• Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
