At atmospheric pressure, ammonia, NH3, is present as a liquid at temperatures below -33.6 °C (-28.5 °F). At 10 bara, the condensation/boiling point is 25 °C (77 °F). For more details about phase transitions, see ammonia phase diagram.
Below the tables, properties of liquid ammonia at saturation pressure as function of temperatur, are shown in figures.
Thermal properties of liquid ammonia at saturation pressure :
| Temperature - t - (oC) | Density - ρ - (kg/m3) |
Specific Heat | Thermal Conductivity - λ - (W/(m K)) | Dynamic Viscosity - η - ( 10-6 Pa s) | Prandtl's no. |
| -50 | 698 | 4.45 | 0.547 | 317 | 1.98 |
| 0 | 636 | 4.61 | 0.540 | 169 | 1.40 |
| 20 | 609 | 4.74 | 0.521 | 138 | 1.29 |
| 50 | 561 | 5.08 | 0.477 | 103 | 1.26 |
| Temperature - t - (oF) | Density - ρ - (lb/ft3) |
Specific Heat | Thermal Conductivity - λ - (Btu/(hr ft oF) | Dynamic Viscosity - η - ( 10-6 lb/(ft s)) | Prandtl's no. |
| -58 | 43.4 | 1.06 | 0.32 | 213 | 1.98 |
| 32 | 39.7 | 1.10 | 0.31 | 113 | 1.40 |
| 68 | 38 | 1.13 | 0.3 | 93 | 1.29 |
| 122 | 35 | 1.21 | 0.28 | 69 | 1.26 |
• Air Conditioning Systems
• Thermodynamics
Ammonia and health symptoms - smell and threat to life.
Thermodynamic properties of saturated and superheated ammonia R-717 like specific volume, enthalpy and entropy.
Specific Heat of Common Liquids and Fluids
