Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
- Isobaric specific heat (Cp) is used for air in a constant pressure (ΔP = 0) system.
- I sochoric specific heat (Cv) is used for air in a constant-volume , (= isovolumetric or isometric ) closed system.
The specific heat of dry air - CP and CV - will vary with pressure and temperature. This may influence on the accuracy of industrial air handling process calculations. When calculating mass and volume flow of air in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the figures and table below.
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature, Density at varying pressure, Diffusion Coefficients for Gases in Air, Prandtl Number, Specific heat at varying temperature, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight,
as well as Specific heat of Ammonia, Butane, Carbon dioxide, Carbon monoxide, Ethane, Ethanol, Ethylene, Hydrogen, Methane, Methanol, Nitrogen, Oxygen, Propane and Water.
Specific Heat of dry air at constant temperature 20 oC / 68°F at various pressures:
Specific Heat of dry air at selected temperatures at various pressures:
Specific Heat of dry air at constant temperature 20 oC (68°F) at varying pressures:
For full table with Isochloric Heat Capacity - rotate the screen!
Pressure | Isobaric Specific Heat, Cp | Isochoric Specific Heat, Cv | Specific Heat Ratio | ||||||||
(atm) | (psia) | (kPa) | (kJ/kgK) | (kWh/(kg K)) | (kcal/(kg °C)), (Btu/(lb °F)) | (kcal/(lb °F)) | (kJ/kgK) | (kWh/(kg K)) | (kcal/(kg °C)), (Btu/(lb °F)) | (kcal/(lb °F)) | Cp/Cv |
0.01 | 0.147 | 1.01325 | 1.0045 | 0.00027903 | 0.2399 | 0.1959 | 0.71740 | 0.00019928 | 0.1713 | 0.1399 | 1.4002 |
0.1 | 1.47 | 10.1325 | 1.0049 | 0.00027914 | 0.2400 | 0.1960 | 0.71763 | 0.00019934 | 0.1714 | 0.1399 | 1.4003 |
0.4 | 5.88 | 40.53 | 1.0053 | 0.00027925 | 0.2401 | 0.1960 | 0.71766 | 0.00019935 | 0.1714 | 0.1400 | 1.4008 |
11) | 14.7 | 101.325 | 1.0061 | 0.00027947 | 0.2403 | 0.1962 | 0.71767 | 0.00019935 | 0.1714 | 0.1400 | 1.4019 |
7 | 102.9 | 709.28 | 1.0162 | 0.00028228 | 0.2427 | 0.1982 | 0.71913 | 0.00019976 | 0.1718 | 0.1402 | 1.4131 |
10 | 147 | 1013.25 | 1.0216 | 0.00028378 | 0.2440 | 0.1992 | 0.72005 | 0.00020001 | 0.1720 | 0.1404 | 1.4188 |
40 | 588 | 4053 | 1.0756 | 0.00029878 | 0.2569 | 0.2098 | 0.72858 | 0.00020238 | 0.1740 | 0.1421 | 1.4763 |
70 | 1029 | 7092.8 | 1.1305 | 0.00031403 | 0.2700 | 0.2205 | 0.73778 | 0.00020494 | 0.1762 | 0.1439 | 1.5323 |
100 | 1470 | 10132.5 | 1.1824 | 0.00032845 | 0.2824 | 0.2306 | 0.74703 | 0.00020751 | 0.1784 | 0.1457 | 1.5828 |
Unit conversion:
british thermal unit(International table) = (Btu(IT)), degree celcius = (°C), degree fahrenheit = (°F), degree kelvin = (K), degree rankin = (°R), joule = (J), kilocalorie(International table) = (kcal(IT)), kilogram = (kg), kilojoule = (kJ), kilowatthour = (kWh), mole = (mol), pound =(lb)
K in the units can be replaced by °C, and vise versa. °R in the units can be replaced by °F, and vise versa.
- 1 Btu/(lb °F) = 1 Btu/(lb °R) = 1 kcal(IT)/(kg °C) = 1 kcal(IT)/(kg K) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
- 1 J/(kg K) = 1 J/(kg °C) = 2.3885×10-4 kcal(IT)/(kg oC) = 2.3885×10-4 Btu/(lb °F) = 1.9501×10-4 kcal(IT)/(lb °F)
- 1 kcal(IT)/(kg °C) = 1 Btu/(lb °F) = 4186.8 J/(kg K) = 0.81647 kcal(IT)/(lb °F) = 1.163×10-3 kWh/(kg K)
- 1 kcal(IT)/(lb °F) = 1.2248 Btu/(lb °F) = 1.2248 kcal(IT)/(kg °C) = 5127.9 J/(kg K)
- 1 kJ/kgK = 1 kJ/(kg °C) = 1000 J/(kg K) = 1000 J/(kg °C) = 0.23885 kcal(IT)/(kg °C) = 0.23885 Btu/(lb °F) = 0.19501 kcal(IT)/(lb °F) = 2.7778×10-4 kWh/(kg K)
- 1 kWh/(kg K) = 0.85985 kcal(IT)/(kg °C) = 0.85985 Btu/(lb °F) = 3.6 kJ/kgK
- 1 mol of air = 28.96546 g
• Air Psychrometrics
• Gases and Compressed Air
Air - Humidity Ratio
Air - Prandtl Number
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Air Properties: Temperature, Pressure & Density Data
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
International Standard Atmosphere
International standard atmosphere in elevation -2000 to 30000 metre - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Pressure
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Specific Heat of Common Materials – Engineering Reference
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
