- T -
(K)
See also other properties of Methane at varying temperature and pressure : Density and specific weight , Dynamic and kinematic viscosity , Thermal conductivity and Prandtl number , and Thermophysical properties at standard conditions ,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature , Air - at Constant Temperature and Varying Pressure , Ammonia , Butane , Carbon dioxide , Carbon monoxide , Ethane , Ethanol , Ethylene , Hydrogen , Methanol , Nitrogen , Oxygen , Propane and Water .
Gas marks on gas ovens and heat or temperature developed.
Sizing gas pipes for apartment service lines.
Carrying capacity of house gas pipes - in imperial and metric units.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Sizing low pressure natural gas pipe lines - Imperial units.
