No. of Apartments | Nominal Size of Gas Pipe (inches) | ||||||||
Length of Service Pipe (feet) | |||||||||
120 | 130 | 140 | 150 | 160 | 170 | 180 | 190 | 200 | |
4 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
8 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
10 | 2 | 2 | 2 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
12 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
14 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
16 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
20 | 2.5 | 2.5 | 2.5 | 3 | 3 | 3 | 3 | 3 | 3 |
24 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
30 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
40 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
48 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 |
The table is based on schedule 40 steel pipe and can be used for a low pressure services lines with pressure head 6 inH2O and gas with 0.6 specific gravity and pressure drop 0.3 inH2O.
Carrying capacity of house gas pipes - in imperial and metric units.
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Natural gas consumption for equipment like boiling pans, ovens, cookers, kettles and more.
Calculate capacities and dimensions of natural gas pipe lines.
Sizing low pressure natural gas pipe lines - Imperial units.
Sizing natural gas pipes - pressures above 5 psi (35 kPa).
Sizing of low pressure propane gas pipe lines - Imperial units.
