Ethane Gas - Specific Heat vs. Temperature
Specific heat (C) is the amount of heat required to change the temperature of a mass unit of a substance by one degree.
- Isobaric specific heat (Cp) is used for substances in a constant pressure (ΔP = 0) system.
- I sochoric specific heat (Cv) is used for substances in a constant-volume (= isovolumetric or isometric ) closed system.
The specific heat - CP and CV - will vary with temperature. When calculating mass and volume flow of a substance in heated or cooled systems with high accuracy - the specific heat (= heat capacity) should be corrected according values in the table below.
Specific heat of Ethane Gas - C2H6 - at temperatures ranging 250 - 900 K:
Temperature - T - (K) | Specific Heat - cp - (kJ/kgK) |
250 | 1.535 |
275 | 1.651 |
300 | 1.766 |
325 | 1.878 |
350 | 1.987 |
375 | 2.095 |
400 | 2.199 |
450 | 2.402 |
500 | 2.596 |
550 | 2.782 |
600 | 2.958 |
650 | 3.126 |
700 | 3.286 |
750 | 3.438 |
800 | 3.581 |
850 | 3.717 |
900 | 3.846 |
See also other properties of Ethane at varying temperature and pressure: Density and Specific Weight, Dynamic and Kinematic Viscosity and Thermal conductivity, and Thermophysical properties at standard conditions,
as well as Specific heat of Air - at Constant Pressure and Varying Temperature, Air - at Constant Temperature and Varying Pressure, Ammonia, Butane, Carbon dioxide, Carbon monoxide, Ethanol, Ethylene, Hydrogen, Methane, Methanol, Nitrogen, Oxygen, Propane and Water.
Combustion Heat
Ethane Liquid - Thermal Properties
Density, specific heat and more of liquid ethane.
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Refrigerants
Commonly used refrigerants - the methane series, ethane series, propane series, cyclic organic compounds, zeotropic blends, azeotropic blends and organic compounds.
