Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                          (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = m g / V
   = ρ g                            (2)
Tabulated values of ethanol density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online Ethanol Density Calculator
The calculator below can be used to estimate the density and specific weight of liquid ethanol at given temperature.
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
See also other properties of Ethanol at varying temperature and pressure : Dynamic and kinematic viscosity and Specific heat (Heat capacity), and Thermophysical properties at standard conditions,
as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water .
Density and specific weight of ethanol along the boiling and condensation curve, SI and Imperial units:
Density of liquid ethanol at varying temperature (°C) and given pressures:
The density of liquid ethanol is nearly the same for all pressures up to 100 bara, and the density of the liquid at equilibrium pressure (as used in the calculator above) can be used for most practical purposes.
Density of ethanol vapor (singel phase) at varying temperature and given pressures, SI and Imperial units:
Density and specific weight of ethanol at given temperatures and pressures:
(K) (°C) (°F) (MPa) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lbm/ft3) (sl/ft3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
250 -23.2 -9.7 0.000270 0.00270 0.0392 17.91 825.2 51.51 1.601 8092 51.5
280 6.9 44.3 0.00258 0.0258 0.375 17.38 800.5 49.97 1.553 7850 50.0
310 36.9 98.3 0.0153 0.153 2.22 16.83 775.3 48.40 1.504 7603 48.4
340 66.9 152 0.0635 0.635 9.22 16.23 747.8 46.68 1.451 7333 46.7
370 96.9 206 0.2021 2.021 29.30 15.56 716.7 44.74 1.391 7029 44.7
400 127 260 0.5245 5.245 76.07 14.77 680.6 42.49 1.321 6675 42.5
423.9 151 303 1.000 10.00 145.0 14.05 647.2 40.41 1.256 6347 40.4
430 157 314 1.165 11.65 169.0 13.84 637.7 39.81 1.237 6254 39.8
460 187 368 2.292 22.92 332.4 12.68 584.0 36.46 1.133 5727 36.5
490 217 422 4.095 40.95 594.0 11.01 507.1 31.66 0.9839 4973 31.7
501.4 228 443 5.000 50.00 725.2 10.01 461.3 28.80 0.8951 4524 28.8
513.9 241 465 6.148 61.48 891.7 5.991 276.0 17.23 0.5355 2707 17.2
Gas at
equilibrium
250 -23.2 -9.7 0.000270 0.00270 0.039 0.00013 0.0060 0.00037 0.00001 0.059 0.00037
280 6.9 44.3 0.00258 0.0258 0.375 0.00111 0.0512 0.00320 0.00010 0.502 0.00320
298.2 25.0 77.0 0.0080 0.0800 1.16 0.00315 0.145 0.00905 0.00028 1.42 0.00905
310 36.9 98.3 0.0153 0.153 2.22 0.00598 0.276 0.0172 0.00053 2.70 0.0172
340 66.9 152 0.0635 0.635 9.22 0.02298 1.058 0.0661 0.0021 10.4 0.0661
370 96.9 206 0.2021 2.021 29.30 0.06904 3.181 0.1986 0.0062 31.2 0.1986
400 127 260 0.5245 5.245 76.07 0.1739 8.009 0.5000 0.0155 78.5 0.5000
423.9 151 303 1.000 10.00 145.0 0.3310 15.25 0.9518 0.0296 150 0.9518
430 157 314 1.165 11.65 169.0 0.3868 17.82 1.113 0.0346 175 1.113
460 187 368 2.292 22.92 332.4 0.7963 36.69 2.290 0.0712 360 2.290
490 217 422 4.095 40.95 594.0 1.614 74.37 4.643 0.1443 729 4.643
501.4 228 443 5.000 50.00 725.2 2.181 100.5 6.272 0.1950 985 6.272
513.9 241 465 6.148 61.48 891.7 5.991 276.0 17.23 0.5355 2707 17.23
Liquid 300 26.9 80.3 0.1 1 14.5 17.02 783.9 48.94 1.521 7688 48.94
351.1 77.9 172 0.1 1 14.5 15.99 736.8 46.00 1.430 7226 46.00
Gas 351.1 77.9 172 0.1 1 14.5 0.03531 1.627 0.1016 0.0032 16.0 0.102
400 127 260 0.1 1 14.5 0.03058 1.409 0.0879 0.0027 13.8 0.088
500 227 440 0.1 1 14.5 0.02419 1.114 0.0696 0.0022 10.9 0.070
600 327 620 0.1 1 14.5 0.02009 0.93 0.0578 0.0018 9.07 0.058
Liquid 300 26.9 80.3 1 10 145 17.03 784.8 48.99 1.523 7696 48.99
400 127 260 1 10 145 14.80 681.6 42.55 1.323 6684 42.55
423.9 151 303 1 10 145 14.05 647.2 40.41 1.256 6347 40.41
Gas 423.9 151 303 1 10 145 0.3310 15.25 0.9518 0.0296 150 0.952
500 227 440 1 10 145 0.2557 11.78 0.7353 0.0229 116 0.735
600 327 620 1 10 145 0.2044 9.415 0.5878 0.0183 92.3 0.588
Liquid 300 26.9 80.3 5 50 725 17.11 788.3 49.21 1.530 7731 49.21
400 127 260 5 50 725 14.96 689.3 43.03 1.337 6759 43.03
501.4 228 443 5 50 725 10.01 461.3 28.80 0.8951 4524 28.80
Gas 501.4 228 443 5 50 725 2.181 100.5 6.272 0.1950 985 6.272
600 327 620 5 50 725 1.137 52.39 3.271 0.1017 514 3.271
Liquid 300 26.9 80.3 10 100 1450 17.20 792.5 49.48 1.538 7772 49.48
400 127 260 10 100 1450 15.15 697.8 43.56 1.354 6843 43.56
500 227 440 10 100 1450 11.52 530.8 33.14 1.030 5205 33.14
Supercritical
phase
600 327 620 10 100 1450 2.800 129.0 8.053 0.2503 1265 8.053
Liquid 300 26.9 80.3 100 1000 14500 18.39 847.2 52.89 1.644 8308 52.89
400 127 260 100 1000 14500 17.03 784.6 48.98 1.522 7694 48.98
500 227 440 100 1000 14500 15.41 709.8 44.31 1.377 6961 44.31
Supercritical
phase
600 327 620 100 1000 14500 13.60 626.6 39.12 1.216 6145 39.12
Liquid 300 26.9 80.3 200 2000 29000 19.24 886.6 55.35 1.720 8694 55.35
400 127 260 200 2000 29000 18.14 835.6 52.17 1.621 8195 52.17
500 227 440 200 2000 29000 16.88 777.6 48.54 1.509 7625 48.54
Supercritical
phase
600 327 620 200 2000 29000 15.51 714.3 44.59 1.386 7005 44.59
Phase diagram of ethanol
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Bio Ethanol Production - Raw Materials
Raw materials used for Ethanol Bio-fuel production.
Combustion Heat
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Methanol - Thermophysical Properties vs. Temperature
Thermophysical properties of methanol.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Naming of Organic Compounds
Nomenclature rules for different groups of organic compounds and functional groups, together with examples of use of the rules.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
