ρ = m / V (1)
γ = m g / V
= ρ g (2)
Tabulated values of methanol density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Online M ethanol Density Calculator
The calculator below can be used to estimate the density and specific weight of methanol at given temperature and atmospheric pressure. (Boiling point of methanol is -0.8°C / 30.5°F, and thus, methanol is present as liquid below this temperature)
See also other properties of Methanol at varying temperature and pressure : Dynamic and kinematic viscosity and Specific heat (Heat capacity), and Thermophysical properties at standard conditions, as well as density and specific weight of acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethane, ethanol, ethylene, helium, hydrogen, methane, nitrogen, oxygen, pentane, propane, toluene and water .
Density of methanol at varying temperature and pressure, SI and Imperial units:
The density of liquid methanol is nearly the same for all pressures up to 100 bara and 25 °C (77°F), and the density of the liquid at equilibrium pressure can be used for most practical purposes.
Density of methanol at varying temperature and equilibrium pressure, SI and Imperial units:
Density and specific weight of methanol at given temperatures and pressures:
State | Temperature | Pressure | Density | Specific weight | |||||||
(K) | (°C) | (°F) | (bara) | (psia) | (mol/dm3) | (g/l), (kg/m3) | (lb/ft3) | (sl/ft3) | (N/m3) | (lbf/ft3) | |
Liquid at equilibrium |
175.61 | -97.54 | -143.57 | 1.86E-06 | 2.70E-05 | 28.23 | 904.5 | 56.47 | 1.755 | 8870 | 56.47 |
210 | -63.2 | -81.7 | 1.98E-04 | 0.00288 | 27.16 | 870.3 | 54.33 | 1.689 | 8535 | 54.33 | |
240 | -33.2 | -27.7 | 0.00363 | 0.0527 | 26.25 | 841.1 | 52.51 | 1.632 | 8248 | 52.51 | |
270 | -3.1 | 26.3 | 0.0332 | 0.481 | 25.36 | 812.5 | 50.72 | 1.577 | 7968 | 50.72 | |
300 | 26.9 | 80.3 | 0.187 | 2.71 | 24.48 | 784.5 | 48.97 | 1.522 | 7693 | 48.97 | |
330 | 56.9 | 134 | 0.745 | 10.8 | 23.59 | 755.8 | 47.18 | 1.467 | 7412 | 47.18 | |
360 | 86.9 | 188 | 2.30 | 33.3 | 22.64 | 725.3 | 45.28 | 1.407 | 7113 | 45.28 | |
390 | 117 | 242 | 5.86 | 85.0 | 21.57 | 691.1 | 43.15 | 1.341 | 6778 | 43.15 | |
420 | 147 | 296 | 12.9 | 187 | 20.32 | 650.9 | 40.63 | 1.263 | 6383 | 40.63 | |
450 | 177 | 350 | 25.4 | 369 | 18.74 | 600.5 | 37.49 | 1.165 | 5889 | 37.49 | |
480 | 207 | 404 | 45.7 | 663 | 16.55 | 530.4 | 33.11 | 1.029 | 5201 | 33.11 | |
513.38 | 240.23 | 464.414 | 82.2 | 1191 | 8.785 | 281.5 | 17.57 | 0.5462 | 2760 | 17.57 | |
Gas at equilibrium |
175.61 | -97.54 | -143.57 | 1.86E-06 | 2.70E-05 | 1.28E-07 | 4.09E-06 | 2.55E-07 | 7.94E-09 | 4.01E-05 | 2.55E-07 |
210 | -63.2 | -81.7 | 1.98E-04 | 0.00288 | 1.14E-05 | 3.65E-04 | 2.28E-05 | 7.07E-07 | 0.00358 | 2.28E-05 | |
240 | -33.2 | -27.7 | 0.00363 | 0.05278 | 1.83E-04 | 0.00586 | 3.66E-04 | 1.14E-05 | 0.05751 | 3.66E-04 | |
270 | -3.1 | 26.3 | 0.0332 | 0.4818 | 0.00150 | 0.04793 | 0.00299 | 9.30E-05 | 0.4700 | 0.00299 | |
300 | 26.9 | 80.3 | 0.187 | 2.71 | 0.00768 | 0.2462 | 0.01537 | 4.78E-04 | 2.415 | 0.01537 | |
330 | 56.9 | 134 | 0.745 | 10.8 | 0.02844 | 0.9112 | 0.05688 | 0.00177 | 8.935 | 0.05688 | |
360 | 86.9 | 188 | 2.30 | 33.3 | 0.08327 | 2.668 | 0.1666 | 0.00518 | 26.16 | 0.1665 | |
390 | 117 | 242 | 5.86 | 85.0 | 0.2067 | 6.624 | 0.4135 | 0.01285 | 64.96 | 0.4135 | |
420 | 147 | 296 | 12.9 | 187 | 0.4607 | 14.76 | 0.9215 | 0.02864 | 144.8 | 0.9215 | |
450 | 177 | 350 | 25.4 | 369 | 0.9622 | 30.83 | 1.925 | 0.05982 | 302.3 | 1.925 | |
480 | 207 | 404 | 45.7 | 663 | 1.910 | 61.20 | 3.821 | 0.1188 | 600.2 | 3.821 | |
Liquid | 200 | -73.2 | -99.7 | 1 | 14.5 | 27.47 | 880.3 | 54.95 | 1.708 | 8632 | 54.95 |
300 | 26.9 | 80.3 | 1 | 14.5 | 24.49 | 784.5 | 48.98 | 1.522 | 7694 | 48.98 | |
337.3 | 64.15 | 147.47 | 1 | 14.5 | 23.37 | 748.6 | 46.74 | 1.453 | 7342 | 46.74 | |
Gas | 337.3 | 64.15 | 147.47 | 1 | 14.5 | 0.03763 | 1.206 | 0.07526 | 0.002339 | 11.82 | 0.07526 |
400 | 127 | 260 | 1 | 14.5 | 0.03045 | 0.9757 | 0.06091 | 0.001893 | 9.568 | 0.06091 | |
500 | 227 | 440 | 1 | 14.5 | 0.02416 | 0.7740 | 0.04832 | 0.001502 | 7.590 | 0.04832 | |
600 | 327 | 620 | 1 | 14.5 | 0.02009 | 0.6437 | 0.04018 | 0.001249 | 6.312 | 0.04018 | |
Liquid | 200 | -73.2 | -99.7 | 10 | 145 | 27.49 | 880.8 | 54.99 | 1.709 | 8638 | 54.99 |
300 | 26.9 | 80.3 | 10 | 145 | 24.51 | 785.4 | 49.03 | 1.524 | 7702 | 49.03 | |
400 | 127 | 260 | 10 | 145 | 21.19 | 679.0 | 42.39 | 1.318 | 6659 | 42.39 | |
409.75 | 136.60 | 277.88 | 10 | 145 | 20.77 | 665.5 | 41.55 | 1.291 | 6527 | 41.55 | |
Gas | 409.75 | 136.60 | 277.88 | 10 | 145 | 0.3535 | 11.33 | 0.7071 | 0.02198 | 111.1 | 0.7071 |
500 | 227 | 440 | 10 | 145 | 0.2520 | 8.075 | 0.5041 | 0.01567 | 79.19 | 0.5041 | |
600 | 327 | 620 | 10 | 145 | 0.2050 | 6.569 | 0.4101 | 0.01275 | 64.42 | 0.4101 | |
Liquid | 200 | -73.2 | -99.7 | 50 | 725 | 27.56 | 883.1 | 55.13 | 1.713 | 8660 | 55.13 |
300 | 26.9 | 80.3 | 50 | 725 | 24.64 | 789.3 | 49.27 | 1.532 | 7740 | 49.27 | |
400 | 127 | 260 | 50 | 725 | 21.44 | 687.0 | 42.89 | 1.333 | 6737 | 42.89 | |
484.95 | 211.80 | 413.24 | 50 | 725 | 16.08 | 515.1 | 32.16 | 0.9994 | 5051 | 32.16 | |
Gas | 484.95 | 211.80 | 413.24 | 50 | 725 | 2.171 | 69.56 | 4.343 | 0.1350 | 682.2 | 4.343 |
500 | 227 | 440 | 50 | 725 | 1.768 | 56.64 | 3.536 | 0.1099 | 555.5 | 3.536 | |
600 | 327 | 620 | 50 | 725 | 1.139 | 36.49 | 2.278 | 0.07080 | 357.8 | 2.278 | |
Liquid | 200 | -73.2 | -99.7 | 100 | 1450 | 27.65 | 885.8 | 55.30 | 1.719 | 8687 | 55.30 |
300 | 26.9 | 80.3 | 100 | 1450 | 24.78 | 793.9 | 49.56 | 1.540 | 7786 | 49.56 | |
400 | 127 | 260 | 100 | 1450 | 21.72 | 695.8 | 43.44 | 1.350 | 6824 | 43.44 | |
500 | 227 | 440 | 100 | 1450 | 15.93 | 510.5 | 31.87 | 0.9905 | 5006 | 31.87 | |
Supercritical phase |
600 | 327 | 620 | 100 | 1450 | 2.664 | 85.35 | 5.329 | 0.1656 | 837.0 | 5.329 |
Liquid | 200 | -73.2 | -99.7 | 1000 | 14504 | 28.91 | 926.3 | 57.83 | 1.797 | 9084 | 57.83 |
300 | 26.9 | 80.3 | 1000 | 14504 | 26.63 | 853.2 | 53.27 | 1.656 | 8367 | 53.27 | |
400 | 127 | 260 | 1000 | 14504 | 24.49 | 784.8 | 48.99 | 1.523 | 7696 | 48.99 | |
500 | 227 | 440 | 1000 | 14504 | 22.02 | 705.5 | 44.04 | 1.369 | 6919 | 44.04 | |
600 | 327 | 620 | 1000 | 14504 | 19.14 | 613.2 | 38.28 | 1.190 | 6014 | 38.28 |
• Densities
• Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Mass vs. Weight
Methanol - Thermophysical Properties
Chemical, physical and thermal properties of methanol, CH3OH (also called carbinol, wood alcohol, hydroxy methyl and methyl alcohol). Phase diagram included.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
