Density , ρ, has units typically (kg/m3) or (lb/ft3), and is defined by the ratio of the mass to the volume of a substance:
ρ = m / V                           (1)
Specific weight , γ, has units typically (N/m3) or (lbf/ft3)  is defined by the ratio of the weight to the volume of a substance:
γ = m g / V
   = ρ g                          (2)
Tabulated values of ethane density and specific weight at given temperature and pressure (SI and Imperial units) as well as density units conversion are given below the figures.
Phase diagram of ethane
Online Ethane Density Calculator
The calculator below can be used to estimate the density and specific weight of ethane at given temperature and atmospheric pressure. (Boiling point of ethane is -88°C / -127°F, and thus, ethane is present as liquid below this temperature)
The output density is given as kg/m3, lb/ft3, lb/gal(US liq) and sl/ft3.  Specific weight is given as N/m3 and lbf/ ft3.
See also other properties of Ethane at varying temperature and pressure: Dynamic and Kinematic Viscosity, Specific Heat (Heat Capacity) and Thermal conductivity, and Thermophysical properties at standard conditions,
as well as density and specific weight o f acetone, air, ammonia, argon, benzene, butane, carbon dioxide, carbon monoxide, ethanol, ethylene, helium, hydrogen, methane, methanol, nitrogen, oxygen, pentane, propane, toluene and water . Density of crude oil , Density of fuel oils , Density of lubricating oil and Density of jet fuel as function of temperature.
Density and specific weight of gaseous ethane at varying temperature and atmospheric pressure, SI and Imperial units:
Density and specific weight of liquid ethane at varying temperature and atmospheric pressure, SI and Imperial units:
Density of ethane at varying temperature and pressure, SI and Imperial units:
The density of liquid ethane is nearly the same for all pressures up to 100 bara and -50 °C (-60°F), and the density of the liquid at equilibrium pressure can be used for most practical purposes.
Density of ethane at varying temperature and equilibrium pressure, SI and Imperial units:
Density and specific weight of ethane at given temperatures and pressures:
(K) (°C) (°F) (bara) (psia) (mol/dm3) (g/l),
(kg/m3)
(lb/ft3) (sl/ft3) (N/m3) (lbf/ft3)
Liquid at
equilibrium
90.368 -182.78 -297.01 1.14E-05 1.65E-04 21.67 651.6 40.68 1.264 6390 40.7
100 -173 -280 1.11E-04 0.00161 21.32 641.0 40.01 1.244 6286 40.0
120 -153 -244 0.00352 0.05110 20.58 619.0 38.64 1.201 6070 38.6
140 -133 -208 0.0381 0.553 19.84 596.6 37.24 1.158 5851 37.2
160 -113 -172 0.2141 3.105 19.07 573.6 35.81 1.113 5625 35.8
200 -73.2 -99.7 2.172 31.51 17.43 524.0 32.71 1.017 5139 32.7
220 -53.2 -63.7 4.921 71.37 16.50 496.3 30.98 0.9629 4867 31.0
250 -23.2 -9.7 13.01 188.7 14.90 448.1 27.97 0.8694 4394 28.0
270 -3.1 26.3 22.10 320.5 13.56 407.7 25.45 0.7911 3998 25.5
290 16.9 62.3 35.16 509.9 11.68 351.3 21.93 0.6817 3445 21.9
305.32 32.17 89.91 48.72 706.6 6.857 206.2 12.87 0.4001 2022 12.9
Gas at
equilibrium
90.368 -182.78 -297.01 1.14E-05 1.65E-04 1.52E-06 4.57E-05 2.85E-06 8.87E-08 4.48E-04 2.85E-06
100 -173 -280 1.11E-04 0.00161 1.33E-05 4.01E-04 2.50E-05 7.78E-07 0.00393 2.50E-05
120 -153 -244 0.00352 0.05110 3.53E-04 0.01062 6.63E-04 2.06E-05 0.104 6.63E-04
140 -133 -208 0.0381 0.553 3.29E-03 0.2325 0.01451 4.51E-04 2.28 0.0145
160 -113 -172 0.2141 3.11 0.01626 0.9274 0.05790 0.00180 9.10 0.0579
200 -73.2 -99.7 2.172 31.51 0.1387 4.171 0.2604 0.00809 40.9 0.260
220 -53.2 -63.7 4.921 71.4 0.2999 9.018 0.5630 0.01750 88.4 0.563
250 -23.2 -9.7 13.01 188.7 0.7846 23.59 1.473 0.04578 231 1.47
270 -3.1 26.3 22.10 320.5 1.400 42.09 2.628 0.08167 413 2.63
290 16.9 62.3 35.16 509.9 2.568 77.22 4.820 0.1498 757 4.82
Liquid 90.38 -182.77 -296.99 1 14.5 21.67 651.5 40.67 1.264 6389 40.7
100 -173 -280 1 14.5 21.32 641.0 40.02 1.244 6286 40.0
120 -153 -244 1 14.5 20.59 619.0 38.64 1.201 6070 38.6
140 -133 -208 1 14.5 19.84 596.6 37.24 1.158 5851 37.2
160 -113 -172 1 14.5 19.08 573.6 35.81 1.113 5625 35.8
180 -93.2 -136 1 14.5 18.28 549.5 34.30 1.066 5389 34.3
184.33 -88.82 -127.88 1 14.5 18.10 544.1 33.97 1.056 5336 34.0
Gas 184.33 -88.82 -127.88 1 14.5 0.06751 2.030 0.1267 0.00394 19.9 0.127
200 -73.2 -99.7 1 14.5 0.06173 1.856 0.1159 0.00360 18.2 0.116
220 -53.2 -63.7 1 14.5 0.05574 1.676 0.1046 0.00325 16.4 0.105
240 -33.2 -27.7 1 14.5 0.05085 1.529 0.09545 0.00297 15.0 0.0955
260 -13.2 8.3 1 14.5 0.04679 1.407 0.08784 0.00273 13.8 0.0878
280 6.9 44.3 1 14.5 0.04334 1.303 0.08134 0.00253 12.8 0.0813
300 26.9 80.3 1 14.5 0.04038 1.214 0.07579 0.00236 11.9 0.0758
320 46.9 116 1 14.5 0.03781 1.137 0.07098 0.00221 11.2 0.0710
340 66.9 152 1 14.5 0.03555 1.069 0.06674 0.00207 10.5 0.0667
360 86.9 188 1 14.5 0.03356 1.009 0.06299 0.00196 9.89 0.0630
400 127 260 1 14.5 0.03015 0.9067 0.05660 0.00176 8.89 0.0566
500 227 440 1 14.5 0.02409 0.7242 0.04521 0.00141 7.10 0.0452
600 327 620 1 14.5 0.02006 0.6031 0.03765 0.00117 5.91 0.0377
700 427 800 1 14.5 0.01718 0.5167 0.03226 0.00100 5.07 0.0323
800 527 980 1 14.5 0.01503 0.4520 0.02822 8.77E-04 4.43 0.0282
900 627 1160 1 14.5 0.01336 0.4018 0.02508 7.80E-04 3.94 0.0251
1000 727 1340 1 14.5 0.01203 0.3616 0.02257 7.02E-04 3.55 0.0226
Liquid 90.53 -182.62 -296.72 10 145 21.67 651.7 40.68 1.265 6391 40.7
100 -173 -280 10 145 21.33 641.3 40.04 1.244 6289 40.0
120 -153 -244 10 145 20.60 619.4 38.67 1.202 6074 38.7
140 -133 -208 10 145 19.86 597.2 37.28 1.159 5857 37.3
160 -113 -172 10 145 19.10 574.3 35.85 1.114 5632 35.9
180 -93.2 -136 10 145 18.31 550.4 34.36 1.068 5398 34.4
200 -73.2 -99.7 10 145 17.46 524.9 32.77 1.018 5148 32.8
220 -53.2 -63.7 10 145 16.53 497.1 31.03 0.9645 4875 31.0
240 -33.2 -27.7 10 145 15.48 465.4 29.05 0.9030 4564 29.1
241.1 -32.1 -25.7 10 145 15.42 463.5 28.94 0.8993 4545 28.9
Gas 241.1 -32.1 -25.7 10 145 0.6000 18.04 1.126 0.03500 177 1.13
260 -13.2 8.3 10 145 0.5298 15.93 0.9945 0.03091 156 0.994
280 6.9 44.3 10 145 0.4763 14.32 0.8940 0.02779 140 0.894
300 26.9 80.3 10 145 0.4347 13.07 0.8159 0.02536 128 0.816
320 46.9 116 10 145 0.4008 12.05 0.7523 0.02338 118 0.752
340 66.9 152 10 145 0.3728 11.21 0.6998 0.02175 110 0.700
360 86.9 188 10 145 0.3489 10.49 0.6549 0.02035 103 0.655
400 127 260 10 145 0.3097 9.312 0.5813 0.01807 91.3 0.581
500 227 440 10 145 0.2435 7.323 0.4572 0.01421 71.8 0.457
600 327 620 10 145 0.2015 6.058 0.3782 0.01175 59.4 0.378
700 427 800 10 145 0.1720 5.173 0.3229 0.01004 50.7 0.323
800 527 980 10 145 0.1503 4.518 0.2820 0.00877 44.3 0.282
900 627 1160 10 145 0.1334 4.011 0.2504 0.00778 39.3 0.250
1000 727 1340 10 145 0.1200 3.608 0.2252 0.00700 35.4 0.225
Liquid 100 -173 -280 50 725 21.38 642.9 40.14 1.247 6305 40.1
200 -73.2 -99.7 50 725 17.61 529.5 33.06 1.027 5193 33.1
300 26.9 80.3 50 725 10.91 328.0 20.47 0.6364 3216 20.5
Supercritical
phase
400 127 260 50 725 1.765 53.08 3.314 0.1030 521 3.31
500 227 440 50 725 1.277 38.40 2.397 0.07450 377 2.40
600 327 620 50 725 1.025 30.81 1.923 0.05977 302 1.92
Liquid 91.96 -181.19 -294.14 100 1450 21.73 653.3 40.78 1.268 6407 40.8
100 -173 -280 100 1450 21.44 644.8 40.25 1.251 6323 40.3
120 -153 -244 100 1450 20.74 623.6 38.93 1.210 6115 38.9
140 -133 -208 100 1450 20.03 602.2 37.59 1.168 5906 37.6
160 -113 -172 100 1450 19.30 580.4 36.23 1.126 5692 36.2
180 -93.2 -136 100 1450 18.56 558.1 34.84 1.083 5473 34.8
200 -73.2 -99.7 100 1450 17.79 534.8 33.39 1.038 5245 33.4
220 -53.2 -63.7 100 1450 16.97 510.2 31.85 0.9900 5003 31.9
240 -33.2 -27.7 100 1450 16.09 483.8 30.20 0.9387 4744 30.2
260 -13.2 8.3 100 1450 15.12 454.6 28.38 0.8821 4458 28.4
280 6.9 44.3 100 1450 14.01 421.4 26.31 0.8177 4133 26.3
300 26.9 80.3 100 1450 12.68 381.3 23.80 0.7398 3739 23.8
Supercritical
phase
320 46.9 116 100 1450 10.94 328.8 20.53 0.6380 3224 20.5
340 66.9 152 100 1450 8.511 255.9 15.98 0.4965 2510 16.0
360 86.9 188 100 1450 6.219 187.0 11.67 0.3628 1834 11.7
400 127 260 100 1450 4.197 126.2 7.878 0.2449 1238 7.88
500 227 440 100 1450 2.680 80.57 5.030 0.1563 790 5.03
600 327 620 100 1450 2.076 62.41 3.896 0.1211 612 3.90
700 427 800 100 1450 1.722 51.79 3.233 0.1005 508 3.23
800 527 980 100 1450 1.483 44.59 2.784 0.08652 437 2.78
900 627 1160 100 1450 1.307 39.30 2.453 0.07625 385 2.45
1000 727 1340 100 1450 1.171 35.20 2.197 0.06830 345 2.20
Liquid 100 -173 -280 300 4351 21.68 652.0 40.70 1.265 6394 40.7
200 -73.2 -99.7 300 4351 18.37 552.4 34.49 1.072 5417 34.5
300 26.9 80.3 300 4351 14.78 444.6 27.75 0.8626 4360 27.8
Supercritical
phase
400 127 260 300 4351 10.81 325.1 20.30 0.6308 3188 20.3
500 227 440 300 4351 7.678 230.9 14.41 0.4480 2264 14.4
600 327 620 300 4351 5.893 177.2 11.06 0.3438 1738 11.1
Density units conversion:
Density converter
Densities
Fluid Mechanics
Material Properties
Thermodynamics
Acetone - Density and Specific Weight
Online calculator, figures and tables showing density and specific weight of acetone at temperatures ranging from -95 to 275 °C (-138 to 530 °F) at atmospheric and higher pressure - Imperial and SI Units.
Adiabatic Flame Temperatures
Adiabatic flame temperatures for hydrogen, methane, propane and octane - in Kelvin.
Online calculator, figures and table showing density and specific weight of benzene, C6H6, at temperatures ranging from 5 to 325 °C (42 to 620 °F) at atmospheric and higher pressure - Imperial and SI Units.
Density Converter
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethane Gas - Specific Heat vs. Temperature
Specific heat of Ethane Gas - C2H6 - for temperatures ranging 250 - 900 K.
Ethane Liquid - Thermal Properties
Density, specific heat and more of liquid ethane.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Gases - Specific Heat and Individual Gas Constants
Gases - Speed of Sound
Speed of sound in some gases at zero degrees Celsius and atmospheric pressure.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Mass vs. Weight
Online calculator, figures and tables showing density and specific weight of methanol,CH3OH, at varying temperature and pressure - Imperial and SI Units.
Nitrogen (N₂) Density & Specific Weight: Temperature & Pressure Data and Calculator
Online calculator, figures and tables showing density and specific weight of nitrogen, N2, at temperatures ranging from -175 to 1325 °C (-280 to 2400 °F) at atmospheric and higher pressure - Imperial and SI Units.
