The output dynamic viscosity is given as Pa*s, N*s/m 2 , cP, mPa*s, lb f *s/ft 2 and lb m /(ft*h),
while the kinematic viscosity is given as cSt, m 2 /s, and ft 2 /s
See also other properties of Ethane at varying temperature and pressure: Density and Specific Weight , Specific heat (heat capacity) and Thermal conductivity , and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethanol , ethylene , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic and kinematic viscosity of gaseous ethane at atmospheric pressure and varying temperature:
Dynamic and kinematic viscosity of liquid ethane at atmospheric pressure and varying temperature:
Dynamic viscosity of ethane at varying temperature and 1, 10 and 100 bara (14.5, 145 and 1450 psia):
Kinematic viscosity of ethane at varying temperature and 1, 10 and 100 bara (14.5, 145 and 1450 psia):
Dynamic viscosity of ethane at gas-liquid equilibrium pressure:
Kinematic viscosity of ethane at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of ethane at given temperatures and pressures, SI and Imperial units:
For full table with Imperial units and Kinematic Viscosity - rotate the screen!
State | Temperature | Pressure | Dynamic (Absolute) Viscosity | Kinematic Viscosity | ||||||||
[K] | [°C] | [°F] | [bara] | [psia] | [μPa s] | [cP] | [lb f s/ft 2 *10 -6 ] | [lb m /ft s*10 -6 ] | [lb m /ft h] | [cSt], [m 2 /s*10 -6 ] | [ft 2 /s*10 -6 ] | |
Liquid at equilibrium | 90.368 | -182.78 | -297.01 | 1.14E-05 | 1.65E-04 | 1281 | 1.281 | 26.75 | 860.7 | 3.098 | 1.966 | 21.16 |
100 | -173 | -280 | 1.10E-04 | 0.00161 | 873.2 | 0.8732 | 18.24 | 586.8 | 2.112 | 1.362 | 14.66 | |
120 | -153 | -244 | 0.00352 | 0.05110 | 485.8 | 0.4858 | 10.15 | 326.4 | 1.175 | 0.7848 | 8.448 | |
140 | -133 | -208 | 0.03814 | 1.398 | 319.8 | 0.3198 | 6.679 | 214.9 | 0.7736 | 0.5360 | 5.770 | |
160 | -113 | -172 | 0.2141 | 6.210 | 231.2 | 0.2312 | 4.828 | 155.3 | 0.5592 | 0.4030 | 4.338 | |
200 | -73.2 | -99.7 | 2.172 | 31.51 | 138.3 | 0.1383 | 2.888 | 92.91 | 0.3345 | 0.2639 | 2.840 | |
220 | -53.2 | -63.7 | 4.921 | 71.37 | 110.1 | 0.1101 | 2.298 | 73.95 | 0.2662 | 0.2218 | 2.387 | |
250 | -23.2 | -9.7 | 13.01 | 188.7 | 78.19 | 0.07819 | 1.633 | 52.54 | 0.1891 | 0.1745 | 1.878 | |
270 | -3.1 | 26.3 | 22.10 | 320.5 | 60.94 | 0.060936 | 1.273 | 40.95 | 0.1474 | 0.1495 | 1.609 | |
290 | 16.9 | 62.3 | 35.16 | 509.9 | 44.60 | 0.044603 | 0.9316 | 29.97 | 0.1079 | 0.1270 | 1.366 | |
Gas at equilibrium | 90.368 | -182.78 | -297.01 | 1.14E-05 | 1.65E-04 | 3.043 | 0.003043 | 0.0635 | 2.045 | 0.00736 | 66566 | 716512 |
100 | -173 | -280 | 1.10E-04 | 0.00161 | 3.316 | 0.003316 | 0.06925 | 2.228 | 0.00802 | 8274 | 89059 | |
120 | -153 | -244 | 0.00352 | 0.05110 | 3.896 | 0.003896 | 0.08137 | 2.618 | 0.00943 | 366.8 | 3948 | |
140 | -133 | -208 | 0.03814 | 1.398 | 4.496 | 0.004496 | 0.09389 | 3.021 | 0.01088 | 45.50 | 489.8 | |
160 | -113 | -172 | 0.2141 | 6.21 | 5.110 | 0.005110 | 0.1067 | 3.434 | 0.01236 | 10.449 | 112.5 | |
200 | -73.2 | -99.7 | 2.172 | 31.51 | 6.391 | 0.006391 | 0.1335 | 4.294 | 0.01546 | 1.532 | 16.49 | |
220 | -53.2 | -63.7 | 4.921 | 71.4 | 7.089 | 0.007089 | 0.1481 | 4.764 | 0.01715 | 0.7861 | 8.462 | |
250 | -23.2 | -9.7 | 13.01 | 188.7 | 8.342 | 0.008342 | 0.1742 | 5.606 | 0.02018 | 0.3536 | 3.806 | |
270 | -3.1 | 26.3 | 22.10 | 320.5 | 9.526 | 0.009526 | 0.1989 | 6.401 | 0.02304 | 0.2263 | 2.436 | |
290 | 16.9 | 62.3 | 35.16 | 509.9 | 11.62 | 0.01162 | 0.2426 | 7.806 | 0.02810 | 0.1504 | 1.619 | |
Liquid | 90.38 | -182.77 | -296.99 | 1 | 14.5 | 1281 | 1.281 | 26.75 | 860.8 | 3.099 | 1.966 | 21.16 |
100 | -173 | -280 | 1 | 14.5 | 873.9 | 0.8739 | 18.25 | 587.2 | 2.114 | 1.363 | 14.67 | |
120 | -153 | -244 | 1 | 14.5 | 486.1 | 0.4861 | 10.15 | 326.6 | 1.176 | 0.7853 | 8.453 | |
140 | -133 | -208 | 1 | 14.5 | 320.0 | 0.3200 | 6.683 | 215.0 | 0.7741 | 0.5364 | 5.773 | |
160 | -113 | -172 | 1 | 14.5 | 231.3 | 0.2313 | 4.831 | 155.4 | 0.5595 | 0.4032 | 4.340 | |
180 | -93.2 | -136 | 1 | 14.5 | 176.2 | 0.1762 | 3.680 | 118.4 | 0.4262 | 0.3207 | 3.451 | |
184.33 | -88.82 | -127.88 | 1 | 14.5 | 166.9 | 0.1669 | 3.486 | 112.2 | 0.4037 | 0.3067 | 3.302 | |
Gas | 184.33 | -88.82 | -127.88 | 1 | 14.5 | 5.877 | 0.005877 | 0.1227 | 3.949 | 0.01422 | 2.895 | 31.16 |
200 | -73.2 | -99.7 | 1 | 14.5 | 6.368 | 0.006368 | 0.1330 | 4.279 | 0.01540 | 3.431 | 36.93 | |
220 | -53.2 | -63.7 | 1 | 14.5 | 6.991 | 0.006991 | 0.1460 | 4.698 | 0.01691 | 4.171 | 44.90 | |
240 | -33.2 | -27.7 | 1 | 14.5 | 7.608 | 0.007608 | 0.1589 | 5.112 | 0.01840 | 4.976 | 53.56 | |
260 | -13.2 | 8.3 | 1 | 14.5 | 8.217 | 0.008217 | 0.1716 | 5.522 | 0.01988 | 5.840 | 62.86 | |
280 | 6.9 | 44.3 | 1 | 14.5 | 8.817 | 0.008817 | 0.1841 | 5.925 | 0.02133 | 6.767 | 72.84 | |
300 | 26.9 | 80.3 | 1 | 14.5 | 9.408 | 0.009408 | 0.1965 | 6.322 | 0.02276 | 7.750 | 83.42 | |
320 | 46.9 | 116 | 1 | 14.5 | 9.989 | 0.009989 | 0.2086 | 6.712 | 0.02416 | 8.785 | 94.57 | |
340 | 66.9 | 152 | 1 | 14.5 | 10.56 | 0.01056 | 0.2206 | 7.096 | 0.02555 | 9.878 | 106.330 | |
360 | 86.9 | 188 | 1 | 14.5 | 11.12 | 0.01112 | 0.2322 | 7.472 | 0.02690 | 11.02 | 118.627 | |
400 | 127 | 260 | 1 | 14.5 | 12.21 | 0.01221 | 0.2550 | 8.205 | 0.02954 | 13.47 | 144.951 | |
500 | 227 | 440 | 1 | 14.5 | 14.78 | 0.01478 | 0.3087 | 9.932 | 0.03575 | 20.41 | 219.677 | |
600 | 327 | 620 | 1 | 14.5 | 17.13 | 0.01713 | 0.3578 | 11.51 | 0.04144 | 28.40 | 305.730 | |
700 | 427 | 800 | 1 | 14.5 | 19.32 | 0.01932 | 0.4035 | 12.98 | 0.04674 | 37.39 | 402.474 | |
800 | 527 | 980 | 1 | 14.5 | 21.36 | 0.02136 | 0.4461 | 14.35 | 0.05167 | 47.26 | 508.666 | |
900 | 627 | 1160 | 1 | 14.5 | 23.28 | 0.02328 | 0.4862 | 15.64 | 0.05632 | 57.94 | 623.653 | |
1000 | 727 | 1340 | 1 | 14.5 | 25.10 | 0.02510 | 0.5242 | 16.87 | 0.06072 | 69.41 | 747.162 | |
Liquid | 90.53 | -182.62 | -296.72 | 10 | 145 | 1283 | 1.283 | 26.80 | 862.1 | 3.104 | 1.969 | 21.19 |
100 | -173 | -280 | 10 | 145 | 880.2 | 0.8802 | 18.38 | 591.5 | 2.129 | 1.373 | 14.77 | |
120 | -153 | -244 | 10 | 145 | 489.1 | 0.4891 | 10.22 | 328.7 | 1.183 | 0.7896 | 8.500 | |
140 | -133 | -208 | 10 | 145 | 322.0 | 0.3220 | 6.725 | 216.4 | 0.7789 | 0.5392 | 5.804 | |
160 | -113 | -172 | 10 | 145 | 232.8 | 0.2328 | 4.862 | 156.4 | 0.5632 | 0.4054 | 4.363 | |
180 | -93.2 | -136 | 10 | 145 | 177.5 | 0.1775 | 3.707 | 119.3 | 0.4294 | 0.3225 | 3.471 | |
200 | -73.2 | -99.7 | 10 | 145 | 139.3 | 0.1393 | 2.909 | 93.61 | 0.3370 | 0.2654 | 2.857 | |
220 | -53.2 | -63.7 | 10 | 145 | 110.7 | 0.1107 | 2.312 | 74.39 | 0.2678 | 0.2227 | 2.397 | |
240 | -33.2 | -27.7 | 10 | 145 | 87.85 | 0.08785 | 1.835 | 59.03 | 0.2125 | 0.1888 | 2.032 | |
241.1 | -32.1 | -25.7 | 10 | 145 | 86.70 | 0.0867 | 1.811 | 58.26 | 0.2097 | 0.1871 | 2.013 | |
Gas | 241.1 | -32.1 | -25.7 | 10 | 145 | 7.929 | 0.007929 | 0.1656 | 5.328 | 0.01918 | 0.4395 | 4.731 |
260 | -13.2 | 8.3 | 10 | 145 | 8.485 | 0.008485 | 0.1772 | 5.702 | 0.02053 | 0.5326 | 5.733 | |
280 | 6.9 | 44.3 | 10 | 145 | 9.072 | 0.009072 | 0.1895 | 6.096 | 0.02195 | 0.6335 | 6.819 | |
300 | 26.9 | 80.3 | 10 | 145 | 9.652 | 0.009652 | 0.2016 | 6.486 | 0.02335 | 0.7385 | 7.949 | |
320 | 46.9 | 116 | 10 | 145 | 10.22 | 0.01022 | 0.2134 | 6.868 | 0.02472 | 0.8481 | 9.129 | |
340 | 66.9 | 152 | 10 | 145 | 10.79 | 0.01079 | 0.2254 | 7.251 | 0.02610 | 0.9625 | 10.36 | |
360 | 86.9 | 188 | 10 | 145 | 11.34 | 0.01134 | 0.2368 | 7.620 | 0.02743 | 1.081 | 11.64 | |
400 | 127 | 260 | 10 | 145 | 12.42 | 0.01242 | 0.2594 | 8.346 | 0.03005 | 1.334 | 14.36 | |
500 | 227 | 440 | 10 | 145 | 14.95 | 0.01495 | 0.3122 | 10.05 | 0.03617 | 2.042 | 21.97 | |
600 | 327 | 620 | 10 | 145 | 17.29 | 0.01729 | 0.3611 | 11.62 | 0.04183 | 2.854 | 30.72 | |
700 | 427 | 800 | 10 | 145 | 19.46 | 0.01946 | 0.4064 | 13.08 | 0.04708 | 3.762 | 40.49 | |
800 | 527 | 980 | 10 | 145 | 21.48 | 0.02148 | 0.4486 | 14.43 | 0.05196 | 4.754 | 51.17 | |
900 | 627 | 1160 | 10 | 145 | 23.39 | 0.02339 | 0.4885 | 15.72 | 0.05658 | 5.831 | 62.77 | |
1000 | 727 | 1340 | 10 | 145 | 25.20 | 0.0252 | 0.5263 | 16.93 | 0.06096 | 6.984 | 75.18 | |
Liquid | 100 | -173 | -280 | 50 | 725 | 909.2 | 0.9092 | 18.99 | 610.9 | 2.199 | 1.414 | 15.22 |
200 | -73.2 | -99.7 | 50 | 725 | 144.7 | 0.1447 | 3.022 | 97.23 | 0.3500 | 0.2733 | 2.941 | |
300 | 26.9 | 80.3 | 50 | 725 | 39.65 | 0.039648 | 0.8281 | 26.64 | 0.09591 | 0.1209 | 1.301 | |
Supercritical phase | 400 | 127 | 260 | 50 | 725 | 13.91 | 0.013905 | 0.2904 | 9.344 | 0.03364 | 0.2620 | 2.820 |
500 | 227 | 440 | 50 | 725 | 16.00 | 0.015995 | 0.3341 | 10.75 | 0.03869 | 0.4166 | 4.484 | |
600 | 327 | 620 | 50 | 725 | 18.12 | 0.018124 | 0.3785 | 12.18 | 0.04384 | 0.5883 | 6.333 | |
Liquid | 91.96 | -181.19 | -294.14 | 100 | 1450 | 1310 | 1.310 | 27.36 | 880.3 | 3.169 | 2.005 | 21.58 |
100 | -173 | -280 | 100 | 1450 | 947.3 | 0.9473 | 19.78 | 636.6 | 2.292 | 1.469 | 15.81 | |
120 | -153 | -244 | 100 | 1450 | 520.6 | 0.5206 | 10.87 | 349.8 | 1.259 | 0.8348 | 8.986 | |
140 | -133 | -208 | 100 | 1450 | 342.0 | 0.3420 | 7.143 | 229.8 | 0.8273 | 0.5679 | 6.113 | |
160 | -113 | -172 | 100 | 1450 | 248.1 | 0.2481 | 5.182 | 166.7 | 0.6002 | 0.4275 | 4.601 | |
180 | -93.2 | -136 | 100 | 1450 | 190.5 | 0.1905 | 3.979 | 128.0 | 0.4608 | 0.3413 | 3.674 | |
200 | -73.2 | -99.7 | 100 | 1450 | 151.3 | 0.1513 | 3.160 | 101.7 | 0.3660 | 0.2829 | 3.045 | |
220 | -53.2 | -63.7 | 100 | 1450 | 122.4 | 0.1224 | 2.556 | 82.25 | 0.2961 | 0.2399 | 2.582 | |
240 | -33.2 | -27.7 | 100 | 1450 | 99.96 | 0.09996 | 2.088 | 67.17 | 0.2418 | 0.2066 | 2.224 | |
260 | -13.2 | 8.3 | 100 | 1450 | 81.74 | 0.08174 | 1.707 | 54.93 | 0.1977 | 0.1798 | 1.935 | |
280 | 6.9 | 44.3 | 100 | 1450 | 66.38 | 0.06638 | 1.386 | 44.61 | 0.1606 | 0.1575 | 1.696 | |
300 | 26.9 | 80.3 | 100 | 1450 | 52.87 | 0.05287 | 1.104 | 35.53 | 0.1279 | 0.1387 | 1.492 | |
Supercritical phase | 320 | 46.9 | 116 | 100 | 1450 | 40.36 | 0.04036 | 0.8429 | 27.12 | 0.09763 | 0.1227 | 1.321 |
340 | 66.9 | 152 | 100 | 1450 | 28.77 | 0.02877 | 0.6009 | 19.33 | 0.06960 | 0.1124 | 1.210 | |
360 | 86.9 | 188 | 100 | 1450 | 21.62 | 0.02162 | 0.4515 | 14.53 | 0.05230 | 0.1156 | 1.244 | |
400 | 127 | 260 | 100 | 1450 | 17.94 | 0.01794 | 0.3747 | 12.06 | 0.04340 | 0.1422 | 1.530 | |
500 | 227 | 440 | 100 | 1450 | 17.95 | 0.01795 | 0.3749 | 12.06 | 0.04342 | 0.2228 | 2.398 | |
600 | 327 | 620 | 100 | 1450 | 19.50 | 0.0195 | 0.4073 | 13.10 | 0.04717 | 0.3124 | 3.363 | |
700 | 427 | 800 | 100 | 1450 | 21.26 | 0.02126 | 0.4440 | 14.29 | 0.05143 | 0.4105 | 4.419 | |
800 | 527 | 980 | 100 | 1450 | 23.01 | 0.02301 | 0.4806 | 15.46 | 0.05566 | 0.5160 | 5.555 | |
900 | 627 | 1160 | 100 | 1450 | 24.73 | 0.02473 | 0.5165 | 16.62 | 0.05982 | 0.6293 | 6.773 | |
1000 | 727 | 1340 | 100 | 1450 | 26.40 | 0.0264 | 0.5514 | 17.74 | 0.06386 | 0.7500 | 8.073 | |
Liquid | 100 | -173 | -280 | 300 | 4351 | 1127 | 1.127 | 23.54 | 757.5 | 2.727 | 1.729 | 18.61 |
200 | -73.2 | -99.7 | 300 | 4351 | 177.0 | 0.17704 | 3.698 | 119.0 | 0.4283 | 0.3205 | 3.450 | |
300 | 26.9 | 80.3 | 300 | 4351 | 77.61 | 0.07761 | 1.621 | 52.15 | 0.1877 | 0.1746 | 1.879 | |
Supercritical phase | 400 | 127 | 260 | 300 | 4351 | 42.22 | 0.042216 | 0.8817 | 28.37 | 0.1021 | 0.1298 | 1.398 |
500 | 227 | 440 | 300 | 4351 | 30.51 | 0.03051 | 0.6372 | 20.50 | 0.07381 | 0.1321 | 1.422 | |
600 | 327 | 620 | 300 | 4351 | 27.54 | 0.027539 | 0.5752 | 18.51 | 0.06662 | 0.1554 | 1.673 | |
Liquid | 200 | -73.2 | -99.7 | 700 | 10153 | 230.7 | 0.2307 | 4.818 | 155.0 | 0.5581 | 0.3990 | 4.294 |
300 | 26.9 | 80.3 | 700 | 10153 | 113.5 | 0.11352 | 2.371 | 76.28 | 0.2746 | 0.2283 | 2.457 | |
Supercritical phase | 400 | 127 | 260 | 700 | 10153 | 71.77 | 0.071766 | 1.499 | 48.22 | 0.1736 | 0.1701 | 1.831 |
500 | 227 | 440 | 700 | 10153 | 52.33 | 0.052331 | 1.093 | 35.16 | 0.1266 | 0.1466 | 1.578 | |
600 | 327 | 620 | 700 | 10153 | 44.74 | 0.044741 | 0.9344 | 30.06 | 0.1082 | 0.1467 | 1.579 |
Viscosity Dynamic, Absolute
centipoise [cP], gram/(centimeter second) [g/(cm s)] = poise [P], kilogram/meter second [kg/m s]=newton second/square meter [N s/m 2 ]= pascal second [Pa s], pound/(foot hour) [lb/(ft h)], pound/(foot second) [lb/(ft s)], reyn [reyn]
Viscosity Kinematic
centistoke [cSt] = square millimeter/second [mm 2 /s], square foot/hour [ft 2 /h], square foot/second [ft 2 /s], square inch/second [in 2 /s], square meter/hour [m 2 /h], square meter/second [m 2 /s], stoke [St] = square centimeter/second [cm 2 /s]
