Kinematic Viscosity Converter
The calculator below can be used to convert between kinematic viscosity units:
Kinematic Viscosity Converter Table
The table below can be used to convert between kinematic viscosity units:
Convert fromMultiply with
Convert to
m2/sec m2/min m2/hour stokes (cm2/sec)centiStokes (cSt) cm2/hour cm2/min
m2/sec 1 60 3600 10000 1000000 3.6×107 6×105
m2/min 0.017 1 60 167 16700 6×105 104
m2/hour 2.8×10-4 0.017 1 2.78 278 10000 167
stokes (cm2/sec) 10-4 0.006 0.36 1 100 3600 60
centiStokes (cSt) 10-6 0.00006 0.0036 0.01 1 36 0.6
cm2/hour 2.8×10-8 1.7×10-6 10-4 2.7×10-4 2.7×10-2 1 0.0167
cm2/min 1.7×10-6 10-4 0.006 0.0167 1.67 60 1
in2/sec 6.45×10-4 0.039 2.32 6.45 645 2.3×104 387
in2/min 1.1×10-5 6.45×10-4 0.039 0.11 11 387 6.45
in2/hour 1.79×10-7 1.1×10-5 6.45×10-4 1.79×10-3 1.79×10-1 6.45 0.11
ft2/sec 0.093 5.56 333.3 926 92600 3.33×106 5.56×104
ft2/min 0.0015 0.093 5.57 15.5 1550 5.6×104 928.8
ft2/hour 2.6×10-5 1.55×10-3 0.09 0.26 26 928 15.5
Convert to
in2/sec in2/min in2/hour ft2/sec ft2/min ft2/hour
m2/sec 1550 9.3×104 5.58×106 10.8 646 38800
m2/min 25.8 1550 9.3×104 0.18 10.8 647
m2/hour 0.43 25.8 1550 0.003 0.179 10.8
stokes (cm2/sec) 0.155 9.3 558 0.001 0.0646 3.88
centiStokes (cSt) 0.00155 0.093 5.58 0.00001 0.000646 0.0388
cm2/hour 4.3×10-5 0.0026 0.155 3×10-7 1.79×10-5 0.0011
cm2/min 0.0026 0.155 9.3 1.8×10-5 0.0011 0.065
in2/sec 1 60 3600 0.007 0.42 25.03
in2/min 0.017 1 60 1.2×10-4 6.9×10-3 0.42
in2/hour 2.8×10-4 0.017 1 1.9×10-6 1.16×10-4 6.95×10-3
ft2/sec 143.5 8611 5.2×105 1 59.8 3592.6
ft2/min 2.4 144 8638 0.017 1 60
ft2/hour 0.04 2.4 143.8 2.78×10-4 0.017 1
Download and print Kinematic Viscosity Unit Converting Chart
Kinematic Viscosity Units
  • 1 Stoke = 10-4 m2/s
  • 1 Stoke = 100 centiStokes
  • 1 Stoke = 1 Square centimetre / second
  • 1 Stoke = 3.88 Square foot/hour
  • 1 Stoke = 1.08×10-3 Square foot/second
  • 1 Stoke = 558 Square inch/hour
  • 1 Stoke = 0.155 Square inch/second
  • 1 Stoke = 0.36 Square metre/hour
  • 1 Stoke = 360000 Square millimetre/hour
  • 1 Stoke = 100 Square millimetre/second
  • 1 Stoke = 1 lentor
Fluid Mechanics
Viscosities
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Kinematic Viscosity - Unit Converter
Convert between Centistokes, Saybolt and Redwood seconds.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Unit Factor Method
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
