Friction loss in steel pipes for fluides with various viscosities are indicated in the diagrams below.
Note that kinematic viscosity SSU 32 (1 centiStokes) equals viscosity of water at normal room temperature. Kinematic viscosity SSU 2000 (440 centiStokes) equals SAE 140 Gear Oil.
- 1 psi/ft = 27.7 inH2O/ft = 22.6 kPa/m
- 1 gpm = 0.23 m3/h
Pipe Size 1/2"
Pipe Size 3/4"
Pipe Size 1"
- 1 gpm = 0.23 m3/h
Pipe Size 1 1/4"
Pipe Size 1 1/2"
Pipe Size 2"
Pipe Size 2 1/2"
Pipe Size 3"
Pipe Size 4"
- 1 gpm = 0.23 m3/h
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Steel Pipes Schedule 40 - Pressure Loss
Water flow and pressure loss in schedule 40 steel pipes - Imperial and SI units - gallons per minute, liters per second and cubic meters per hour.
Steel Pipes Schedule 80 - Friction Loss vs. Water Flow Diagram
Water flow in steel pipes schedule 80 - pressure drop and velocity diagrams in SI and Imperial units.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
