Viscous Liquids - Max. Suction Flow Velocities
Avoid higher velocities in suction pipes. Higher velocities increases pressure loss in pipes and the pumps may start to cavitate. For viscous liquids - as a rule of thumb - the suction velocities in front of pumps should be below:
Pipe bore | Max. Suction Velocity | ||
inches | mm | m/s | ft/s |
1 | 25 | 0.3 | 1 |
2 | 50 | 0.33 | 1.1 |
3 | 75 | 0.36 | 1.2 |
4 | 100 | 0.4 | 1.3 |
6 | 150 | 0.43 | 1.4 |
8 | 200 | 0.45 | 1.5 |
10 | 250 | 0.5 | 1.7 |
12 | 300 | 0.5 | 1.7 |
These values depends a lot on the fluid pumped. More about viscosity and viscosities for different fluids:
- Viscosity Conversion Factors - convert between Centistokes, Centiposes, SSU and Degree Engler
- A Viscosity Converting Chart - converting table between Centiposes, milliPascal, CentiStokes and SSU
- Viscosity of common Fluids - viscosity of fluids like motor oil, diesel fuel, peanut oil and many more
• Piping Systems
• Pumps
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Fuel Oil Pumps - Suction Capacities
Single stage and double stage fuel oil pumps and their suction capacities.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Pumps - Suction Head vs. Altitude
The suction head of a water pump is affected by its operating altitude.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
