Fuel Oil Pumps - Suction Capacities
The limitation of a fuel oil pump feeding a burner may often be the suction side. With higher suction lift the "vacuum" in the suction line will evaporate the light fractions of the fuel oil - and the pump starts to choke.
In general there are two types of fuel feeding pumps
  • single stage pumps
  • double stage pumps
A single stage pump consist of only one set of pumping gears and the lift capacity is limited compared to the two stage fuel pump with double set of pumping gears.
  • a single-stage pump is suited for low-level lifts up to 5 - 10 inches of vacuum
  • a two-stage pump is suited for medium-level lifts up to 10 - 15 inches of vacuum
Higher "vacuum" levels requires use of separate lifting pumps and dedicated feeding reservoirs to the fuel pumps.
The total "vacuum" in a fuel oil suction line can roughly be estimated to
  • 1 inch of vacuum for each foot of lift
  • 1 inch of vacuum for each 90o elbow
  • 1 inch for each 10 feet of 3/8 inch horizontal suction pipe
  • 1 inch for each 20 feet of 3/8 inch horizontal suction pipe
Combustion
Combustion Testing
Combusting testing of fuel oil and gas burners.
Fuel Oil Burners
Pot types, gun types and rotary types fuel burners.
Fuel Oil Combustion Values
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Gas Oil - Classification
Classification of gas oil based on BS 2869 - Specification for fuel oils for agricultural, domestic and industrial engines and boilers.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Oil Fuels - Viscosities vs. Temperature
Viscosities of fuel oils vs. temperature.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
