Fuel Oil Combustion Values
The heat or combustion value of a fuel oil can be expressed as the quantity of heat (Btu per gallon) released during the combustion process where the oxygen from the air reacts with the hydrogen and carbon in the fuel.
Combustion or heating values for some common fuels oil grades:
Fuel Oils - Combustion Values vs. Grade
GradeHeating Value
(Btu/US gal)
Comments
Fuel Oil No. 1 132900 - 137000 Small Space Heaters
Fuel Oil No. 2 137000 - 141800 Residential Heating
Fuel Oil No. 4 143100 - 148100 Industrial Burners
Fuel Oil No. 5 (Light) 146800 - 150000 Preheating in General Required
Fuel Oil No.5 (Heavy) 149400 - 152000 Heating Required
Fuel Oil No. 6 151300 - 155900 Bunker C
  • 1 Btu/US gal = 278.7 J/liter
Fuel oil No. 1 and No. 2 fuel are both used for residential heating purposes. The No. 2 is slightly more expensive but the fuel gives more heat per gallon used.
The No. 1 fuel oil is used in vaporizing pot-type burners. The No. 2 is used in atomizing gun-type and rotary fuel oil burners.
Great care must be taken with heavier grades of fuel used in oil burners to ensure that the oil is supplied with the proper atomizing temperature. If the temperature is too low the oil will not atomize and evaporate and the burner will not operate efficiently.
Combustion
Energy Content in common Energy Sources
Heating fuels and their energy content.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Fuel Equivalents - Online Calculator
Online fuels energy equivalents calculator for oil, gas and more.
Fuel Oil Burners
Pot types, gun types and rotary types fuel burners.
Fuel Oil Pumps - Suction Capacities
Single stage and double stage fuel oil pumps and their suction capacities.
Gas Oil - Classification
Classification of gas oil based on BS 2869 - Specification for fuel oils for agricultural, domestic and industrial engines and boilers.
Heating Fuels - Cost Comparing
Cost comparison formulas for heating fuels like Natural Gas, Propane LP Gas, Fuel Oil and Electricity.
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Paraffins and Alkanes - Combustion Properties
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
Standard Reference Fuels and their Equivalents
Convert between fuel equivalents.
Waste Fuel - Heat Values
Fuel from waste products and their heat values.
