Paraffins and Alkanes - Combustion Properties
For full table with Maximum Flame Speed, Adiabatic Flame Temperature, Ignition Temperature, Flash Point and Flammable Limits LEL UEL - rotate the screen!
Paraffin or AlkanesChemical FormulaHigher Heating Value
(Btu/lbm)
Air/Fuel RatioMaximum Flame Speed
(ft/s)
(oF)
(oF)
Flash Point
(oF)
Flammability Limits
LELUEL
Ethane C2H6 22323 15.899 1.3 3540 968 - 1166 *) 3.0 12.5
n-Butane C4H10 21321 14.984 1.2 3583 761 -76 1.9 8.4
iso-Butane C4H10 21271 14.984 1.2 3583 864 -117 1.8 8.4
n-Heptane C7H16 20854 14.141 1.3 3985 433 25 1.0 6.0
n-Hexane C6H14 20966 15.238 1.3 4030 478 -7 1.3 7.0
Methane CH4 23875 17.195 1.1 3484 1301 *) 5.0 15.0
Neopentane C5H12 20978 15.323 1.1 4060 842 *) 1.4 7.2
Neohexane C6H14 20931 15.238 1.2 4055 797 -54 1.2 7.6
n-Octane C8H18 20796 15.093     428 56 0.9 3.2
iso-Octane C8H18 20770 15.093 1.1   837 10 0.8 5.9
n-Pentane C5H12 21095 15.323 1.3 4050 588 < -40 1.4 7.8
iso-Pentane C5H12 21047 15.323 1.2 4055 788 < - 60 1.3 9.2
Propane C3H8 21669 15.246 1.3 3573 871 *) 2.1 10.1
*) gas
  • LEL - Lower Explosive or Flammable Limit
  • UEL - Upper Explosive or Flammable Limit
  • 1 ft/s = 0.3048 m/s
  • T(oC) = 5/9[T(oF) - 32]
  • 1 Btu/lbm = 2,326.1 J/kg = 0.55556 kcal/kg
Combustion
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion Heat
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Combustion Testing
Combusting testing of fuel oil and gas burners.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Fuel Gases - Combustion Values
Combustion values for fuel gases like natural gas, propane and butane - Btu per cubic feet.
Fuel Oil Combustion Values
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Fuels - Higher and Lower Calorific Values
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Fuels Flue Gases - Average Dew Points
Flue gas dew point temperatures for some fuels.
Gross Combustion Values for some common Materials
Gross combustion values for materials like - carbon, methane, ethylene and more - values in Btu/lb.
High and Low Heat Values
The gross (high) and net (low) heating values.
Intermittent Combustion and Boiler Efficiency
Efficiency reduction due to intermittent boiler operation.
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
