Fuels Flue Gases - Average Dew Points
Average dew point temperatures for typical fuels like
  • anthrasite
  • bituminous
  • manufactured gas
  • natural gas
  • oil
  • semi-bitumius
are indicated in the charts below
Excess air is the ratio of air supplied to the combustion process to what is theoretically required for perfect combustion (stoichiometric combustion).
Combustion
Combustion Efficiency and Excess Air
Optimizing boilers efficiency is important to minimize fuel consumption and unwanted excess to the environment.
Combustion Testing
Combusting testing of fuel oil and gas burners.
Flue Gases - Dew Point Temperatures
Flue gas dew point temperatures and condensation of water vapor.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
Paraffins and Alkanes - Combustion Properties
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
Stoichiometric Combustion
Stoichiometric combustion and excess air.
