Stoichiometric Combustion
Stoichiometric or Theoretical Combustion is the ideal combustion process where fuel is burned completely.
A complete combustion is a process burning all the carbon (C) to (CO2), all the hydrogen (H) to (H2O) and all the sulphur (S) to (SO2).
With unburned components in the exhaust gas such as C, H2, CO, the combustion process is uncompleted and not stoichiometric.
The combustion process can be expressed:
(C + H (fuel)) + (O2 + N2 (Air)) -> (Combustion Process) -> (CO2 + H2O + N2 (Heat))
C = Carbon
H = Hydrogen
O = Oxygen
N = Nitrogen
To determine the excess air or excessfuel for a combustion system we starts with the stoichiometric air-fuel ratio. The stoichiometric ratio is the perfect ideal fuel ratio where the chemical mixing proportion is correct. When burned all fuel and air is consumed without any excess left over.
Process heating equipment are rarely run that way. "On-ratio" combustion used in boilers and high temperature process furnaces usually incorporates a modest amount of excess air - about 10 to 20% more than what is needed to burn the fuel completely.
If an insufficient amount of air is supplied to the burner, unburned fuel, soot, smoke, and carbon monoxide exhausts from the boiler - resulting in heat transfer surface fouling, pollution, lower combustion efficiency, flame instability and a potential for explosion.
To avoid inefficient and unsafe conditions boilers normally operate at an excess air level. This excess air level also provides protection from insufficient oxygen conditions caused by variations in fuel composition and "operating slops" in the fuel-air control system. Typical values of excess air are indicated for various fuels in the table below.
  • if air content is higher than the stoichiometric ratio - the mixture is said to be fuel-lean
  • if air content is less than the stoichiometric ratio - the mixture is fuel-rich
Example - Stoichiometric Combustion of Methane - CH4
The most common oxidizer is air. The chemical equation for stoichiometric combustion of methane - CH4 - with air can be expressed as
CH4 + 2(O2 + 3.76 N2) -> CO2 + 2 H2O + 7.52 N2
If more air is supplied some of the air will not be involved in the reaction. The additional air is termed excess air, but the term theoretical air may also be used. 200% theoretical air is 100% excess air.
The chemical equation for methane burned with 25% excess air can be expressed as
CH4 + 1.25 x 2(O2 + 3.76 N2) -> CO2 + 2 H2O + 0.5 O2 + 9.4 N2
Excess Air and O2 and CO2 in Flue Gas
Approximated values for CO2 and O2 in the flue gas as result of excess air are estimated in the table below:
Carbon Dioxide - CO2 - in Flue Gas (% volume)
Excess Air
Natural GasPropane ButaneFuel OilBituminous CoalAnthracite CoalOxygen in Flue Gas for all fuels (% volume)
0 12 14 15.5 18 20 0
20 10.5 12 13.5 15.5 16.5 3
40 9 10 12 13.5 14 5
60 8 9 10 12 12.5 7.5
80 7 8 9 11 11.5 9
100 6 6 8 9.5 10 10
Combustion
Boiler - Efficiency
Combustion gross and net calorific value.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Fuels Flue Gases - Average Dew Points
Flue gas dew point temperatures for some fuels.
Heating Fuels - Cost Comparing
Cost comparison formulas for heating fuels like Natural Gas, Propane LP Gas, Fuel Oil and Electricity.
Methane (CHâ‚„): Thermophysical Properties and Phase Diagram
Optimal Combustion Processes - Fuel vs. Excess Air
Stable and efficient combustion requires correct mixture of fuels and oxygen.
