(Btu/lb)
Combustion heat values of some foods.
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
