Fuel Gases - Combustion Values
Combustion (heat) values for some fuel gases:
Fuel GasCombustion Value
(Btu/ft3)
Specific Gravity
Acetylene 1498 0.91
Blast furnace gas 92 1.02
Butane 3184 1.95 (heavier than air)
Butylene (Butene) 3077 1.94
Carbon Monoxide 323 0.97
Carburated Water Gas 550 0.63
Coke oven 570 0.40
Digester (Sewage) Gas 690 0.80
Ethane 1783 1.06
Hydrogen 325 0.07
Manufactured Gas 500 - 600
Methane 1011 0.55
Natural Gas 950 - 1150 0.660 - 0.708 (lighter than air)
Propane 2504 1.77
Propane-Butane Mix 2500 - 3200
Propylene (Propene) 2332 1.45
Water Gas (bituminous) 261 0.71
  • 1 Btu/ft3 = 8.9 kcal/m3 = 3.73x104 J/m3
Combustion
Fuel Gases - Wobbe Index
Wobbe index for fuel gases like propane, butane, methane and more.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Gases - Gross and Net Heat Values
Gross heat and net heat values for gases like hydrogen, methane and more.
Heating Fuels - Cost Comparing
Cost comparison formulas for heating fuels like Natural Gas, Propane LP Gas, Fuel Oil and Electricity.
Paraffins and Alkanes - Combustion Properties
Properties like heat values, air/fuel ratios, flame speed, flame temperatures, ignition temperatures, flash points and flammability limits.
