Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Pot types, gun types and rotary types fuel burners.
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Single stage and double stage fuel oil pumps and their suction capacities.
Viscosities of fuel oils vs. temperature.
