Oil Fuels - Viscosities vs. Temperatures
Saybolt Universal Seconds - SSU - kinematic viscosity versus temperature for typical fuel oils:
- TF = TC 9 / 5 + 32
- viscosity converting chart
- SSU (Saybolt Universal Seconds) = centiStokes (cSt) x 4.55 1)
- 4 - 5000 SSU is the maximum practical limit for pumping
- 150 - 300 SSU is the atomization range fuel oil no. 5 and 6
1) Note that this equation is correct only for a range of viscosities. There is no linear relationship between the units. Check ASTM D2161 "Standard Practice for Conversion of Kinematic Viscosity to Saybolt Universal Viscosity or to Saybolt Furol Viscosity" for more accurate methods.
• Combustion
• Viscosities
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Fuel Consumption Converter
Convert between fuel consumption units like US MPG, Imperial MPG, litre/nm, litre/100 km and km/litre
Fuel Oil Burners
Pot types, gun types and rotary types fuel burners.
Fuel Oil Pumps - Suction Capacities
Single stage and double stage fuel oil pumps and their suction capacities.
Gas Oil - Classification
Classification of gas oil based on BS 2869 - Specification for fuel oils for agricultural, domestic and industrial engines and boilers.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Kinematic Viscosity - Unit Converter
Convert between Centistokes, Saybolt and Redwood seconds.
Light Oil Pumping - Flow Velocities
Recommended max. flow velocities on the delivery side when pumping light oils.
Liquid Densities
Oil Pipes - Pressure Loss vs. Oil Flow
Pressure drop in oil pipes - viscosities ranging 100 - 600 Saybolt Universal Seconds.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
