The Autoignition Temperature - or
"the minimum temperature required to ignite a gas or vapor in air without a spark or flame being present"
are indicated for common fuels and chemicals below:
ProductAutoignition
Temperature
(oC)
Acetaldehyde 175
Acetic acid 427
Acetone, propanone 465
Acentonitrile 220
Acetylene 305
Acrolein 220
Acronitrile 481
Allylamine 374
Aniline 615
Anthracite - glow point 600
Benzaldehyde 192
Benzene 498
Bituminous coal - glow point 454
Butadiene 420
Butanal 218
Butane 405
1-Butanol 343
Butyl acetate 421
Butyl alcohol 345
Butyl methyl ketone 423
Carbon 700
Carbon disulfide, CS2 90
Carbon monoxide 609
Charcoal 349
Coal-tar oil 580
Coke 700
Cyclohexane 245
Cyclohexanol 300
Cyclohexanone 420
Cyclopropane 498
Dichloromethane 600
Diethylamine 312
Diethyl ether 180
Diethanolamine 662
Diethylamine 662
Diesel, Jet A-1 210
Diisobutyl ketone 396
Diisopropyl ether 443
Dimethyl sulfate 188
Dimethyl sulfide 206
Dimethyl sulphoxide 215
Dodecane, dihexyl 203
Epichlorohydrin 416
Ethane 515
Ethylene, ethene 450
Ethylamine 385
Ethyl acetate 410
Ethyl Alcohol (Ethanol) 363
Ethylene oxide 570
Formaldehyde 424
Fuel Oil No.1 210
Fuel Oil No.2 256
Fuel Oil No.4 262
Furfural 316
Furfural alcohol 491
Heavy hydrocarbons 750
Heptane 204
Hexane 223
Hexadecane, cetane 202
Hydrogen 500
Gas oil 336
Gasoline, Petrol 246 - 280
Glycerol 370
Gun Cotton 221
Kerosene (paraffin) 210
Isobutane 462
Isobutene 465
Isobutyl alcohol 426
Isooctane 447
Isopentane 420
Isoprene 395
Isopropyl alcohol 399
Isophorone 460
Isohexane 264
Isononane 227
Isopropyl Alcohol 399
Light gas 600
Light hydrocarbons 650
Lignite - glow point 526
Magnesium 473
Methane (Natural Gas) 580
Methanol (Methyl Alcohol) 464
Methylamine 430
Methyl acetate 455
Methyl ethyl ketone 516
Naphtha 230
Neoheaxane 425
Neopentane 450
Nitrobenzene 480
Nitro-glycerine 254
n-Butane 405
n-Heptane 215
n-Hexane 225
n-Octane 220
n-Pentane 260
n-Pentene 298
Oak Wood - dry 482
Paper 218 - 246
Paraldehyde 238
Peat 227
Petroleum 400
Petroleum ether 288
Pine Wood - dry 427
Phosphorus, amorphous 260
Phosphorus, transparent 49
Phosphorus, white 34
Production gas 750
Propanal 207
Propane 455
Propyl acetate 450
Propylamine 318
Propylene (Propene) 458
Pyridine 482
p-Xylene 530
Rifle (Gun) Powder 288
Tetrahydrofuran 321
Triethylamine 249
Triethylborane -20
Toluene 480
Semi anthracite coal 400
Semi bituminous coal - glow point 527
Silane < 21
Styrene 490
Sulphur 243
Tetrahydrofuran 321
Toluene 530
Trichloroethylene 420
Wood 300
o-Xylene 463
m-Xylene 527
p-Xylene 528
The flammable (explosive) range is the range of a gas or vapor concentration that will burn or explode if an ignition source is introduced. Limiting concentrations are commonly called the lower explosive or flammable limit (LEL/LFL) and the upper explosive or flammable limit (UEL/UFL).
Below the explosive or flammable limit the mixture is too lean to burn. Above the upper explosive or flammable limit the mixture is too rich to burn. The Auto-Ignition Temperature is not the same as Flash Point - The Flash Point indicates how easy a chemical may burn.
Combustion
HVAC Systems
Heating, ventilation and air conditioning systems - design and dimensions.
Properties of alternative fuels like biodiesel, E85, CNG and more.
ASTM Standard - Volume 05.06 Gaseous Fuels, Coal and Coke
An overview of ASTM Section 5 - Petroleum Products, Lubricants, and Fossil Fuels - Volume 05.06 Gaseous Fuels, Coal and Coke.
Biogas - Carbon Nitrogen Ratios
Carbon - Nitrogen ratios for biogas produced from various raw materials.
Biogas - Potential from Animal Manure
Potential biogas production from animal manure.
Butane - Thermophysical Properties
Chemical, physical and thermal properties of n-Butane.
Chemicals - Formulas and Trading Names
Formulas and trading names for some common chemicals.
Classification of Gases
Oxidizers vs. inert vs. flammable gases.
Coal - Classification
Classification of coal based on volatile matter and cooking power of clean material.
Combustion Appliances - Exhaust Temperatures
Exhaust and outlet temperatures fuels like natural gas, liquefied petroleum, diesel and more.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Flash Points - Liquids
The flash points for some common liquids and fuels.
Fuel Gases - Heating Values
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Fuel Oil Burners
Pot types, gun types and rotary types fuel burners.
Fuel Oil Combustion Values
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Fuels - Boiling Points
Fuels and their boiling points.
Fuels - Combustion Air and Flue Gases
Combustion air and flue gas for common fuels - coke, oil, wood, natural gas and more.
Fuels - Densities and Specific Volumes
Densities and specific volumes fuels like anthracite, butane, gasoil, diesel, coke, oil, wood and more.
Fuels - Higher and Lower Calorific Values
Higher and lower calorific values (heating values) for fuels like coke, oil, wood, hydrogen and others.
Gaseous Fuels - Chemical Composition
Chemical composition of gaseous fuels like coal gas, natural gas, propane and more.
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Heating Fuels - Cost Comparing
Cost comparison formulas for heating fuels like Natural Gas, Propane LP Gas, Fuel Oil and Electricity.
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
Hydrocarbons - Vapor Pressures
Vapor pressure vs. temperature for propane, n-butane, n-heptane and n-pentane hydrocarbons.
Chemical, Physical and Thermal Properties of Hydrogen - H2.
LPG - Gas Properties
Liquefied Petroleum - LP - gas properties.
Methane Gas - Specific Heat vs. Temperature
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Oil Fuels - Viscosities vs. Temperature
Viscosities of fuel oils vs. temperature.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Piston Engines - Displacement
Calculate piston engine displacement.
Standard Grade Coal - Heat Values
Standard grades coal heat values.
Toluene Liquid - Thermal Properties vs. Temperature
