Biogas - Potential from Animal Manure
Biogas refers to a mixture of different gases produced by the breakdown of organic matter in the absence of oxygen. Biogas is produced from raw materials such as agricultural waste, manure, municipal waste, plant material, sewage, green waste or food waste.
Potential biogas production from animals manure:
AnimalManureBiogas
(kgwet_weight/day)(MJ/day)(m3/day)(MJ/day)
Cow 40 62 1.2 26
Hen 0.19 0.9 0.18 3.8
Pig 2.3 6.2 0.18 3.8
  • 1 kg = 2.2046 lb
  • 1 J (Joule) = 2.778×10-7 kWh = 9.478×10-4 Btu
  • 1 m3 = 35.31 ft3
Environment
Animals - Laboratory Environments
Temperature and humidity environments for laboratory animals.
Biogas - Carbon Nitrogen Ratios
Carbon - Nitrogen ratios for biogas produced from various raw materials.
Biogas - Composition
Typical composition of biogas produced from household waste.
Biogas - Energy Content
Energy content in biogas produced from municipal and industrial waste.
Combustion Heat
Density of Gases
Gases - Specific Gravities
Specific gravities of air, ammonia, butadiene, carbon dioxide, carbon monoxide and some other common gases.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
