Standard Grade Coal - Heat Values
Approximate Lower Heating values of standard grades of coal:
Coal GradeHeating Value
(Btu/lb)(kJ/kg)
Anthracite 12910 30080
Semi-Anthracite 13770 32084
Low-volatile bituminous 14340 33412
Medium-volatile bituminous 13840 32247
High-volatile bituminous A 13090 30499
High-volatile bituminous B 12130 28262
High-volatile bituminous C 10750 25047
Sub-bituminous B 9150 21319
Sub-bituminous C 8940 20830
Lignite 6900 16077
  • Anthracite Coal is very shiny, hard black coal, high carbon content and energy density, repels moisture, for domestic industrial uses, including smokeless fuel
  • Bituminous Coal is softer and shiny, moisture content is 8 -20%, possible for coking coals, volatile matter from 16% - 40%, can be used for thermal or metallurgical applications
  • Sub-bituminous Coal is soft and black with energy density lower than bituminous coal, most common type for electricity generation
  • Lignite Coal is light brown with high moisture content and low energy density, used mainly for electricity generation
Combustion
Anthracite Coal
Anthracite coal is available in a number of different grades.
Coal - Classification
Classification of coal based on volatile matter and cooking power of clean material.
Combustion of Fuels - Carbon Dioxide Emission
Environmental emission of carbon dioxide CO2 when combustion fuels like coal, oil, natural gas, LPG and bio energy.
Food - Calorific Combustion Values
Combustion heat values of some foods.
Fossil vs. Alternative Fuels - Energy Content
Net (low) and gross (high) energy content in fossil and alternative fuels.
Gaseous Fuels - Chemical Composition
Chemical composition of gaseous fuels like coal gas, natural gas, propane and more.
High and Low Heat Values
The gross (high) and net (low) heating values.
Nitrogen Oxides (NOx) Emission from Fuels
Emission of Nitrogen Oxides - NOx - with combustion of fuels like oil, coal, propane and more.
Solids - Specific Heats
Stoker Classification
Coal stokers classified on basis of coal burning capacities.
