Anthracite Coal
Anthracite coal is available in a number of different grades or sizes as
  • buckwheat
  • egg
  • stove
  • chestnut
  • pea
  • broken
Each size is suited for different sizes of grates and firepots.
  • Buckwheat coal is used in automatic coal firing burners in domestic, commercial and industrial stokers
  • Egg sized coal are used in large firepots. Usually with beds more than 16 inches deep
  • Stove sized coal is used for heating buildings etc. Mostly replaced with gas or oil
  • Chestnut size coal is used in medium firepots, usually with beds ranging 10 - 15 inches
Combustion
Coal - Classification
Classification of coal based on volatile matter and cooking power of clean material.
Standard Grade Coal - Heat Values
Standard grades coal heat values.
Stoker Classification
Coal stokers classified on basis of coal burning capacities.
