(Btu)
1) Residual Fuel Oil - The liquid or semi-liquid, high-boiling fraction of residue from the distillation of crude oil.
The unit of heat in the imperial system - the BTU - is
An item using one kilowatt-hour of electricity will generate 3412 Btu.
Convert between different biomass energy units.
Calculate fuel consumption in liter per km - consumption chart and calculator.
Convert between energy units
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Combustion values in Btu/gal for fuel oils No.1 to No.6.
The gross (high) and net (low) heating values.
Resistance and pressure loss in liquid LPG pipes.
Fuel from waste products and their heat values.
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
