Note that
One weight unit of wood has enough energy to evaporate 6 weight units of water.
Convert between different biomass energy units.
Some biomass fuels and their higher heating values (HHV).
Heating fuels and their energy content.
The cord unit for purchasing fuel wood.
Trees species and relative water demand.
Height of trees commonly used in towns and urban areas.
Fuel from waste products and their heat values.
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
The density of wood versus moisture content.
