Urban Tree Heights
Trees commonly used in towns and urban areas:
Typical Heights of Urban Trees
Tree SpecieNormal Height (m)
after 25 yearsas mature
Acacia 14 21
Ailanthus 18 21
Almond 7 8
Birch 10 18
Catalpa 10 12
Cherry, gean 12 15
Cherry, bird 7 14
Chestnut 7 12
Crab apple 6 12
Hawthorn 6 8
Lime 10 18
Maidenhair 7 30
Maple, field 7 10
Maple, silver 15 25
Mountain ash 7 8
Oak, evergreen 7 28
Oak, scarlet 15 18
Plane 12 28
Sycamore 12 25
Tulip tree 12 30
Whitebeam 7 12
Environment
Miscellaneous
Density of Wood Species: Data & Material Guide
Fire Wood - the Cord
The cord unit for purchasing fuel wood.
Structural Lumber - Properties
Tree Species - Water Demand
Trees species and relative water demand.
Wood - Combustion Heat Values
Combustion of wood and firewood heat values for species like Pine, Elm, Hickory and more.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood and Bio Mass - Combustion Heat
Combustion heat values for wet and dry wood - Btu/pounds, kJ/kg and kcal/kg.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
