Wood Columns - Safe Loads
Safe loads for Wood Columns - No.1 grade Douglas fir-larch:
  • a kip is a non-SI unit of force - it equals 1,000 pounds-force
  • 1 kip = 4448 Newtons (N) = 4.45 kilo Newtons (kN) = 453 kgf
Example - Safe Loads with 4x4 Douglas Fir-Larch Column
According the diagram above - the safe loads for 4x4 Douglas Fir-Larch Columns with lengths 7.5 feet (2.5 m) are approximately 8 kips (35.6 kN, 3624 kgf).
Beams and Columns
Density of Wood Species: Data & Material Guide
Euler Column Buckling: Formula, Theory & Calculator
Calculate buckling of columns.
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
Machine Stress Rated (MSR) and Machine Evaluated (MEL) Lumber
Grading of lumber in North America
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Steel Pipe Columns - Allowable Loads
Allowable concentric loads for steel pipe columns.
Tree Species - Water Demand
Trees species and relative water demand.
Urban Tree Heights
Height of trees commonly used in towns and urban areas.
Wood - Compressive Strength vs. Moisture Content
Red Spruce, Longleaf Pine and Douglas Fir - moisture content and their compressive strength.
Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Wood Beams - Strength of Material
Wood Headers - Max. Supported Weight
Wood, Panel and Structural Timber Products - Mechanical Properties
Density, fibre stress, compressive strength and modulus of elasticity of clear wood, panel and structural timber products.
