Value
The equivalent of 100 Btu energy can be approximated to 0.0025 nm3 of natural gas as indicated in the chart below.
The SI-system, unit converters, physical constants, drawing scales and more.
Calculate fuel consumption in liter per km - consumption chart and calculator.
Combustion values in Btu/gal for fuel oils No.1 to No.6.
Convert between fuel equivalents.
