Water - Max. Suction Flow Velocities vs. Pipe Size
Capacity problems, cavitation and high power consumption in pumps, are often results of the conditions on the suction side.
In general - as a rule of thumb - keep the suction fluid flow speed below the following values:
Pipe boreMax. Suction Velocity
inchesmmm/sft/s
1 25 0.5 1.5
2 50 0.5 1.6
3 75 0.5 1.7
4 100 0.55 1.8
6 150 0.6 2
8 200 0.75 2.5
10 250 0.9 3
12 300 1.4 4.5
More about NPSH and suction problems:
Piping Systems
Pumps
Water Systems
Boiling Fluids - Max Suction Flow Velocities
Recommended max suction flow velocity when pumping boiling fluids.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Fuel Oil Pumps - Suction Capacities
Single stage and double stage fuel oil pumps and their suction capacities.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Pipe Line Velocities vs. Fluid
Typical fluid flow velocities for common liquids, gases and vapors.
Pipe Velocity Calculator with Flow Data & Charts
Calculate fluid velocity and volume flow in pipes and tubes.
Pumps - NPSH (Net Positive Suction Head)
An introduction to pumps and the Net Positive Suction Head (NPSH).
Pumps - Suction Head vs. Altitude
The suction head of a water pump is affected by its operating altitude.
Viscous Liquids - Max. Delivery Flow Velocities
Recommended max. flow velocities on delivery sides of pumps in viscous systems.
Viscous Liquids - Max. Suction Flow Velocities
Recommended max. pump suction flow velocity for viscous fluids.
Recommended max. water flow velocities on suction sides of pumps.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
