The viscosity of a fluid is a measure of its resistance to gradual deformation by shear stress or tensile stress .
Tabulated values and viscosity units conversion are given below the figures.
Online Air Viscosity Calculator
The calculator below can be used to calculate air dynamic or kinematic viscosity at given temperatures and atmospheric pressure.
The output dynamic viscosity is given as Pas, Ns/m2, cP, mPas, lbfs/ft2 and lbm/fth, while the kinematic viscosity is given as cSt, m2/s and ft2/s.
Note! Temperature must be within the ranges -100 - 1600 °C, -150 - 2900 °F, 175 - 1900 K and 310 -3400 °R to get valid values.
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature, Density at varying pressure, Diffusion Coefficients for Gases in Air, Prandtl Number, Specific heat at varying temperature and Specific heat at varying pressure, Thermal Conductivity, Thermal Diffusivity, Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight,
as well as dynamic and kinematic viscosity of ammonia, benzene, butane, carbon dioxide, ethane, ethanol, ethylene, methane, methanol, nitrogen, oxygen, propane and water.
Air dynamic and kinematic viscosity at atmospheric pressure and varying temperature:
Air dynamic viscosity at varying temperature and constant pressures (1-10 000 bara, 14.5 - 145 000 psia):
Air kinematic viscosity at varying temperature and constant pressures (1-10 000 bara, 14.5 - 145 000 psia):
Air dynamic and kinematic viscosity at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of air at 1 atmosphere pressure, at temperatures given as °F:
For full table with kinematic viscosity - rotate the screen!
| Temperature | Dynamic Viscosity | Kinematic Viscosity | ||||
| (°F) | (lbf s/ft2 ×10-6) | (lbm/ft h) | (μPa s), (N s/m2 ×10-6) | (cP), (mPa s) | (ft2/s ×10-4) | (cSt), (m2/s ×10-6) |
| -100 | 0.2772 | 0.03211 | 13.27 | 0.01327 | 0.809 | 7.51 |
| -50 | 0.3091 | 0.03580 | 14.80 | 0.01480 | 1.028 | 9.55 |
| -20 | 0.3275 | 0.03794 | 15.68 | 0.01568 | 1.170 | 10.87 |
| 0 | 0.3395 | 0.03932 | 16.25 | 0.01625 | 1.267 | 11.77 |
| 10 | 0.3454 | 0.04001 | 16.54 | 0.01654 | 1.317 | 12.24 |
| 20 | 0.3512 | 0.04068 | 16.82 | 0.01682 | 1.368 | 12.71 |
| 30 | 0.3570 | 0.04135 | 17.10 | 0.01710 | 1.420 | 13.19 |
| 40 | 0.3628 | 0.04202 | 17.37 | 0.01737 | 1.472 | 13.67 |
| 50 | 0.3685 | 0.04268 | 17.64 | 0.01764 | 1.524 | 14.16 |
| 60 | 0.3741 | 0.04333 | 17.91 | 0.01791 | 1.578 | 14.66 |
| 70 | 0.3797 | 0.04398 | 18.18 | 0.01818 | 1.632 | 15.16 |
| 80 | 0.3852 | 0.04462 | 18.45 | 0.01845 | 1.687 | 15.67 |
| 100 | 0.3962 | 0.04589 | 18.97 | 0.01897 | 1.799 | 16.71 |
| 120 | 0.4069 | 0.04713 | 19.48 | 0.01948 | 1.913 | 17.78 |
| 140 | 0.4175 | 0.04835 | 19.99 | 0.01999 | 2.030 | 18.86 |
| 160 | 0.4279 | 0.04956 | 20.49 | 0.02049 | 2.150 | 19.97 |
| 180 | 0.4381 | 0.05074 | 20.98 | 0.02098 | 2.272 | 21.11 |
| 200 | 0.4481 | 0.05191 | 21.46 | 0.02146 | 2.397 | 22.27 |
| 250 | 0.4726 | 0.05474 | 22.63 | 0.02263 | 2.719 | 25.26 |
| 300 | 0.4962 | 0.05747 | 23.76 | 0.02376 | 3.055 | 28.38 |
| 350 | 0.5189 | 0.06010 | 24.85 | 0.02485 | 3.405 | 31.64 |
| 400 | 0.5409 | 0.06265 | 25.90 | 0.02590 | 3.769 | 35.02 |
| 450 | 0.5622 | 0.06512 | 26.92 | 0.02692 | 4.146 | 38.52 |
| 500 | 0.5828 | 0.06751 | 27.91 | 0.02791 | 4.535 | 42.13 |
| 600 | 0.6224 | 0.07209 | 29.80 | 0.02980 | 5.349 | 49.70 |
| 700 | 0.6600 | 0.07644 | 31.60 | 0.03160 | 6.209 | 57.68 |
| 773 | 0.6863 | 0.07949 | 32.86 | 0.03286 | 6.864 | 63.77 |
| 1000 | 0.7632 | 0.08840 | 36.54 | 0.03654 | 9.038 | 83.97 |
| 1200 | 0.8258 | 0.09565 | 39.54 | 0.03954 | 11.12 | 103.3 |
| 1400 | 0.8844 | 0.1024 | 42.35 | 0.04235 | 13.34 | 123.9 |
| 1600 | 0.9397 | 0.1088 | 44.99 | 0.04499 | 15.70 | 145.8 |
| 1800 | 0.9919 | 0.1149 | 47.49 | 0.04749 | 18.18 | 168.9 |
| 2000 | 1.042 | 0.1207 | 49.87 | 0.04987 | 20.79 | 193.1 |
Dynamic (absolute) and kinematic viscosity of air at 1 atmosphere pressure, at temperatures given as °C:
| (°C) | (μPa s), (N s/m2 ×10-6) | (cP), (mPa s) | (lbf s/ft2 ×10-6) | (lbm/ft h) | (cSt), (m2/s ×10-6) | (ft2/s ×10-4) |
| -75 | 13.18 | 0.01318 | 0.2753 | 0.03188 | 7.40 | 0.796 |
| -50 | 14.56 | 0.01456 | 0.3041 | 0.03523 | 9.22 | 0.992 |
| -25 | 15.88 | 0.01588 | 0.3317 | 0.03842 | 11.18 | 1.203 |
| -15 | 16.40 | 0.01640 | 0.3425 | 0.03966 | 12.01 | 1.292 |
| -10 | 16.65 | 0.01665 | 0.3477 | 0.04028 | 12.43 | 1.338 |
| -5 | 16.90 | 0.01690 | 0.3530 | 0.04089 | 12.85 | 1.383 |
| 0 | 17.15 | 0.01715 | 0.3582 | 0.04149 | 13.28 | 1.430 |
| 5 | 17.40 | 0.01740 | 0.3633 | 0.04209 | 13.72 | 1.477 |
| 10 | 17.64 | 0.01764 | 0.3685 | 0.04268 | 14.16 | 1.524 |
| 15 | 17.89 | 0.01789 | 0.3735 | 0.04327 | 14.61 | 1.573 |
| 20 | 18.13 | 0.01813 | 0.3786 | 0.04385 | 15.06 | 1.621 |
| 25 | 18.37 | 0.01837 | 0.3836 | 0.04443 | 15.52 | 1.671 |
| 30 | 18.60 | 0.01860 | 0.3885 | 0.04500 | 15.98 | 1.720 |
| 40 | 19.07 | 0.01907 | 0.3983 | 0.04614 | 16.92 | 1.822 |
| 50 | 19.53 | 0.01953 | 0.4080 | 0.04725 | 17.88 | 1.925 |
| 60 | 19.99 | 0.01999 | 0.4175 | 0.04835 | 18.86 | 2.030 |
| 80 | 20.88 | 0.02088 | 0.4361 | 0.05051 | 20.88 | 2.248 |
| 100 | 21.74 | 0.02174 | 0.4541 | 0.05260 | 22.97 | 2.473 |
| 125 | 22.79 | 0.02279 | 0.4760 | 0.05513 | 25.69 | 2.765 |
| 150 | 23.80 | 0.02380 | 0.4971 | 0.05758 | 28.51 | 3.069 |
| 175 | 24.78 | 0.02478 | 0.5176 | 0.05995 | 31.44 | 3.384 |
| 200 | 25.73 | 0.02573 | 0.5374 | 0.06225 | 34.47 | 3.710 |
| 225 | 26.66 | 0.02666 | 0.5567 | 0.06448 | 37.60 | 4.047 |
| 300 | 29.28 | 0.02928 | 0.6115 | 0.07083 | 47.54 | 5.117 |
| 412 | 32.87 | 0.03287 | 0.6865 | 0.07952 | 63.82 | 6.869 |
| 500 | 35.47 | 0.03547 | 0.7409 | 0.08581 | 77.72 | 8.366 |
| 600 | 38.25 | 0.03825 | 0.7988 | 0.09252 | 94.62 | 10.19 |
| 700 | 40.85 | 0.04085 | 0.8532 | 0.09883 | 112.6 | 12.12 |
| 800 | 43.32 | 0.04332 | 0.9047 | 0.1048 | 131.7 | 14.17 |
| 900 | 45.66 | 0.04566 | 0.9535 | 0.1104 | 151.7 | 16.33 |
| 1000 | 47.88 | 0.04788 | 1.000 | 0.1158 | 172.7 | 18.59 |
| 1100 | 50.01 | 0.05001 | 1.045 | 0.1210 | 194.6 | 20.95 |
Viscosity Dynamic, Absolute
centipoise (cP), gram/(centimeter second) (g/(cm s)) = poise (P), kilogram/meter second (kg/m s)=newton second/square meter (N s/m2)= pascal second (Pa s), pound/(foot hour) (lb/(ft h)), pound/(foot second) (lb/(ft s)), reyn (reyn)
- 1 cP = 0.001 Pa s = 0.01 P = 0.01 g/(cm sec) = 6.72197×10-4 lb/(ft s) = 2.4191 lb/(ft h)
- 1 lb/(ft h) = 0.00027778 lb/(ft s) = 0.00041338 Pa s = 0.0041338 P = 0.41338 cP
- 1 lb/(ft s) = 3600 lb/(ft h) = 1.48816 Pa s = 14.8816 P = 1488.16 cP
- 1 kg/(m s) = 1 (N s)/m2= 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
- 1 (N s)/m2= 1 kg/(m s) = 1 Pa s = 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.09 lb/(ft h)
- 1 P = 1 g/(cm s) = 0.1 Pa s = 100 cP = 0.067197 lb/(ft s) = 241.909 lb/(ft h)
- 1 Pa s = 1 kg/(m s) = 1 (N s)/m2= 10 P = 1000 cP = 0.672197 lb/(ft s) = 2419.08 lb/(ft h) = 0.00014504 reyn
- 1 reyn = 6894.76 Pa s
See also Absolute or Dynamic Viscosity Unit Converter
Viscosity Kinematic
centistoke (cSt) = square millimeter/second (mm2/s), square foot/hour (ft2/h), square foot/second (ft2/s), square inch/second (in2/s), square meter/hour (m2/h), square meter/second (m2/s), stoke (St) = square centimeter/second (cm2/s)
- 1 cm2/s = 1 St = 100 mm2/s = 100 cSt = 1×10-4 m2/s = 0.36 m2/h = 1.07639×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
- 1 cSt = 1 mm2/s = 0.01 St = 1×10-6 m2/s = 0.0036 m2/h = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
- 1 ft2/h = 2.7778×10-4 ft2/s = 0.04 in2/s = 2.58064×10-5m2/s = 0.09290304 m2/h = 25.8064 cS = 0.258064 St
- 1 ft2/s = 3600 ft2/h = 144 in2/s = 0.09290304 m2/s = 334.451 m2/h = 92903.04 cSt = 929.0304 St
- 1 in2/s = 0.0069444 ft2/s = 25 ft2/h = 0.00064516 m2/s = 2.322576 m2/h = 645.16 cSt = 6.4516 St
- 1 m2/h = 1/3600 m2/s = 2.7778×10-4 m2/s = 2.7778 cm2/s = 277.78 mm2/s = 277.78 cSt = 2.7778 St = 0.00298998 ft2/s = 10.7639 ft2/h = 0.430556 in2/s
- 1 m2/s = 3600 m2/h = 1×104 cm2/s = 1×104 St = 1×106 mm2/s = 1×106 cSt = 10.7639 ft2/s = 38750.08 ft2/h = 1550003 in2/s
- 1 mm2/s = 1 cSt = 1×10-6 m2/s = 0.0036 m2/h = 0.01 cm2/s = 0.01 St = 1.07639×10-5ft2/s = 0.03875008 ft2/h = 0.001550003 in2/s
- 1 St = 1 cm2/s = 100 cSt = 100 mm2/s = 1×10-4 m2/s = 0.36 m2/h = 1.076×10-3 ft2/s = 3.875008 ft2/h = 0.1550003 in2/s
See also Kinematic Viscosity Unit Converter
• Air Psychrometrics
• Gases and Compressed Air
• Viscosities
Air - Humidity Ratio
Air - Prandtl Number
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties: Temperature, Pressure & Density Data
Pressure loss in compressed air pipe lines.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
