Moist Air - Weight of Water Vapor
Grains of moisture per pound of dry air at standard atmospheric pressure at relative humidity ranging 10 - 90% are indicated below.
| Relative Humidity (%) | Water Vapor in Air (grains* water vapor per pound dry air) | |||||||
| Temperature | ||||||||
| (oC) | ||||||||
| -1 | 4 | 10 | 16 | 21 | 27 | 32 | 38 | |
| (oF) | ||||||||
| 30 | 40 | 50 | 60 | 70 | 80 | 90 | 100 | |
| 10 | 3 | 4 | 6 | 8 | 11 | 16 | 21 | 29 |
| 20 | 5 | 7 | 10 | 16 | 21 | 30 | 42 | 58 |
| 30 | 7 | 11 | 14 | 22 | 34 | 46 | 65 | 87 |
| 40 | 9 | 14 | 20 | 30 | 44 | 62 | 85 | 116 |
| 50 | 12 | 18 | 26 | 39 | 55 | 78 | 108 | 147 |
| 60 | 14 | 22 | 32 | 48 | 66 | 92 | 128 | 176 |
| 70 | 17 | 26 | 38 | 54 | 78 | 108 | 152 | 208 |
| 80 | 19 | 29 | 42 | 62 | 88 | 125 | 173 | - |
| 90 | 21 | 33 | 48 | 70 | 100 | 140 | 190 | - |
*grains of water is commonly used in psychrometrics
- 1 grain = 0.000143 lbm = 0.0648 g (7000 grains per lbm)
Same table as above with water vapor in "pounds water vapor per pound dry air".
| Relative Humidity (%) | Water Vapor in Air (pounds water vapor per pound dry air) | |||||||
| (oC) | ||||||||
| (oF) | ||||||||
| 10 | 0.0004 | 0.0006 | 0.0009 | 0.0011 | 0.0016 | 0.0023 | 0.0030 | 0.0041 |
| 20 | 0.0007 | 0.0010 | 0.0014 | 0.0023 | 0.0030 | 0.0043 | 0.0060 | 0.0083 |
| 30 | 0.0010 | 0.0016 | 0.0020 | 0.0031 | 0.0049 | 0.0066 | 0.0093 | 0.0124 |
| 40 | 0.0013 | 0.0020 | 0.0029 | 0.0043 | 0.0063 | 0.0089 | 0.0122 | 0.0166 |
| 50 | 0.0017 | 0.0026 | 0.0037 | 0.0056 | 0.0079 | 0.0112 | 0.0154 | 0.0210 |
| 60 | 0.0020 | 0.0031 | 0.0046 | 0.0069 | 0.0094 | 0.0132 | 0.0183 | 0.0252 |
| 70 | 0.0024 | 0.0037 | 0.0054 | 0.0077 | 0.0112 | 0.0154 | 0.0217 | 0.0297 |
| 80 | 0.0027 | 0.0041 | 0.0060 | 0.0089 | 0.0126 | 0.0179 | 0.0247 | - |
| 90 | 0.0030 | 0.0047 | 0.0069 | 0.0100 | 0.0143 | 0.0200 | 0.0272 | - |
• Air Psychrometrics
Air - Prandtl Number
Air Properties: Temperature, Pressure & Density Data
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Heat Recovery Efficiency
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Saturated Salt Solutions - Controlling Air Humidity
A salt solutions can be used maintain a particular value of relative humidity.
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
