Saturated Salt Solutions - Controlling Air Humidity
Saturated salt/water solutions can be used to maintain particular values of relative humidities inside sealed containers. A saturated salt solutions is a slushy mixture based on distilled water and a chemically pure salt.
Saturated salt/water solutions can be used to calibrate humidity sensors. Note that the values below may vary with several percents due to temperature variations, impurities in salt or water or slow saturation.
| Saturated Salt Solution | Temperature (ºC) | ||||||||||
| 0 | 5 | 10 | 15 | 20 | 25 | 30 | 35 | 40 | 50 | 60 | |
| Relative Humidity over the Salt Solution (%) | |||||||||||
| Ammonium nitrate - NH4NO3 | 75 | 70 | 67 | 64 | 60 | 53 | |||||
| Ammonium sulphate - (NH4)2SO4 | 82 | 82 | 82 | 82 | 81 | 81 | 81 | 80 | 80 | 79 | |
| Lithium chloride - LiCl 1) | 11.31 | 11.35 | 11.28 | 11.25 | 11.21 | 11.10 | 10.95 | ||||
| Magnesium chloride - MgCl2 | 34 | 34 | 33 | 33 | 33 | 33 | 32 | 32 | 32 | 31 | 29 |
| Magnesium nitrate - Mg(NO3)2 | 60 | 59 | 57 | 56 | 54 | 53 | 51 | 50 | 48 | 45 | |
| Natrium Cloride - NaCl 1) | 75.51 | 75.65 | 75.67 | 75.61 | 75.47 | 75.29 | 75.09 | 74.87 | |||
| Potassium sulphate - K2SO4 | 99 | 98 | 98 | 98 | 98 | 97 | 97 | 97 | 96 | 96 | |
| Potassium nitrate - KNO3 | 96 | 96 | 96 | 95 | 95 | 94 | 92 | 91 | 89 | 85 | |
| Potassium chloride - KCl | 89 | 88 | 87 | 86 | 85 | 84 | 84 | 83 | 82 | 81 | 80 |
| Potassium acetate - CH3CO2K | 23 | 23 | 23 | 23 | 22 | ||||||
| Potassium hydroxide - KOH | 14 | 12 | 11 | 9 | 8 | 7 | 7 | 6 | 6 | 5 | |
| Sodium chloride - NaCl | 76 | 76 | 76 | 76 | 75 | 75 | 75 | 75 | 75 | 74 | 75 |
| Sodium nitrite - NaNO2 | 65 | 64 | 63 | 62 | 61 | ||||||
| Sodium dichromate - Na2Cr2O7 | 61 | 59 | 57 | 57 | 55 | 54 | 53 | 51 | 50 | 49 | 47 |
1) Saturated aqueous solutions of inorganic salts are convenient for calibration of instruments for measurement of relative humidity
Air - Humidity Ratio
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Outdoor Temperatures and Relative Humidity - U.S. Winter and Summer Conditions
Outdoor summer and winter design temperatures and relative humidity for U.S. states and cities.
Recommended Relative Humidity
Recommended relative humidity level.
Relative Humidity in Production and Process Environments
Recommended relative humidity in production and process environments - like libraries, breweries, storages and more.
