Air - Humidity Ratio
The humidity ratio of moist air can be expressed with
- the mass of water vapor in the humid air - to the mass of dry air, or by
- the partial pressure of vapor in the air - to the partial pressure of the dry air
Humidity Ratio by Mass
Humidity ratio by mass can be expressed as
- the ratio between the actual mass of water vapor present in moist air - to the mass of the dry air
Humidity ratio is normally expressed in kilograms (or pounds) of water vapor per kilogram (or pound) of dry air.
Humidity ratio expressed by mass:
x = mw / ma (1)
x = humidity ratio (kgwater/kgdry_air, lbwater/lbdry_air)
mw = mass of water vapor (kg, lb)
ma = mass of dry air (kg, lb)
Humidity Ratio by Vapor Partial Pressure
Based on the Ideal Gas Law the humidity ratio can be expressed as
x = 0.62198 pw / (pa - pw) (2)
pw = partial pressure of water vapor in moist air (Pa, psi)
pa = atmospheric pressure of moist air (Pa, psi)
The maximum amount of water vapor in the air is achieved when pw = pws the saturation pressure of water vapor at the actual temperature. (2) can be modified to:
xs = 0.62198 pws / (pa - pws) (3)
xs = maximum saturation humidity ratio of air (kgwater/kgair, lbwater/lbdry_air)
pws = saturation pressure of water vapor
The water vapor pressure is small regarding to the atmospheric pressure and the relation between the humidity ratio and the saturation pressure is almost linear.
Note! - be careful with these equations at higher temperatures - as indicated in Temperature and Moisture Holding Capacity of Air.
Maximum specific humidity at some common temperatures:
| Temperature (oC) | Water Vapor Saturation Pressure (Pa) | Maximum Saturation Humidity Ratio - x - (kgw/kga) |
| 0 | 609.9 | 0.003767 |
| 5 | 870 | 0.005387 |
| 10 | 1225 | 0.007612 |
| 15 | 1701 | 0.01062 |
| 20 | 2333 | 0.014659 |
| 25 | 3130 | 0.019826 |
| 30 | 4234 | 0.027125 |
Note that the saturation pressure of water vapor, - and the maximum humidity ratio, increases dramatically with air temperature. This important for the capacity of drying processes.
Example - Humidity Ratio of Moist Air
The humidity ratio for saturated moist air at 20 oC with water vapor partial pressure 2333 Pa at atmospheric pressure of 101325 Pa (1013 mbar, 760 mmHg) can be calculated as:
x = 0.62198 (2333 Pa) / ((101325 Pa) - (2333 Pa))
= 0.0147 (kg/kg)
= 14.7 (g/kg)
• Air Psychrometrics
Air - Absolute Humidity
Absolute humidity is the actual mass of water vapor present in the air water vapor mixture.
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Using steam to humidify air.
Air - Prandtl Number
Air Properties: Temperature, Pressure & Density Data
Dehumidifiers
Classification of dehumidifiers.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Evaporative Cooling
Evaporative cooling tutorial.
Great Sensible Heat Factor - GSHF
The Great Sensible Heat Factor is the ratio sensible to total heat in a cooling coil.
Latent Heat Flow
Mixing of Humid Air
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Enthalpy
Moist Air - Psychrometric Terms
Dry and wet bulb temperature, specific volume, relative humidity, enthalpy and more.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Specific vs. Relative Humidity
Specific humidity of moist air vs. relative humidity, water vapor and air density.
Moisture Content Calculation
Calculate the moisture content in products like wood on wet and dry basis.
Recommended Relative Humidity
Recommended relative humidity level.
Relative Humidity in Production and Process Environments
Recommended relative humidity in production and process environments - like libraries, breweries, storages and more.
Required Air Flow to Remove Moisture
Air flow required to remove vapor production from a room.
Saturated Salt Solutions - Controlling Air Humidity
A salt solutions can be used maintain a particular value of relative humidity.
Water Vapor Saturation Pressure: Data, Tables & Calculator
