Dehumidifiers
Devices to remove moisture from air - dehumidification - can be classified as
- absorption dehumidifiers
- spray dehumidifiers
- refrigeration dehumidifiers
Absorption Dehumidifiers
In an absorption dehumidifier moisture is extracted in a sorbent material.
The sorbent material contains a vast number of microscopic pores where water is absorbed. When the sorbent is saturated it can be dehumidified with hot air. It is an intermittent process where a more complicated control of the air flow through the humidifier is required.
Spray Dehumidifiers
As long as the temperature of water is lower than the dew point of the air flow an air washer or a spray dehumidifier can be used.
The air is dehumidified when moist in the air saturates on the surface of the sprayed water.
Refrigeration Dehumidifiers
In refrigeration dehumidifier the airflow passes a cooled surface where some of the moist in the air saturates. The surface or coil is cooled by a refrigeration unit.
• Air Conditioning Systems
• Air Psychrometrics
Basic air changing state processes - heating, cooling, mixing, humidifying and dehumidifying by adding steam or water - psychometric diagrams and the Mollier charts.
Air - Humidity Ratio
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart to analyze air properties, including temperature, humidity, enthalpy, and dew point at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Air Cooling of Storage Roooms
Heat removed from storage rooms with cooled air.
Cooling and Heating Equations
Cooling Load - Latent and Sensible Heat
Latent and sensible cooling loads to consider when designing HVAC systems.
Dehumidification - Removing Moisture from Air
Dehumidifying by cooling, adsorption or absorption.
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
