Moist Air - Degree of Saturation
Degree of Saturation is the ratio of the humidity ratio of moist air - to the humidity ratio of saturated moist air at the same temperature and pressure.
The Degree of Saturation can be expressed as
μ = x / x s (1)
μ = degree of saturation
x = humidity ratio of the air (kg h20 /kg dry_air )
x s = humidity ratio of the air at saturation at the same temperature and pressure (kg h20 /kg dry_air )
The degree of saturation can also be expressed as:
μ = φ (p a - p ws ) / (p a - p w ) (2)
φ = relative humidity (%)
p w = vapor pressure (mbar)
p ws = saturation vapor pressure at the actual dry bulb temperature (mbar)
p a = atmospheric pressure of moist air (mbar)
Air Psychrometrics
Air - Humidity Ratio
Compressed Air - Water Content
Saturation pressure and maximum water content in compressed air.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Humid Air vs. the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Daltons Law of Partial Pressure
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Enthalpy
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Water - Saturation Pressure vs. Temperature
