Water Content
Air is heated from 20oC to 50oC.
The increased ability to carry moisture can be calculated as
100 % ((83 g/m3) - (17.3 g/m3)) / (17.3 g/m3)
= 380 %
This dramatic change is important to explain why heated air is so much more effective than cold air in drying processes.
Saturation pressure and maximum water content in compressed air.
Dehumidifying by cooling, adsorption or absorption.
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Humidity ratio of moist air to humidity ratio of saturated moist air.
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Saturation pressure of water vapor in moist air vs. temperature.
Air flow required to remove vapor production from a room.
