Humid Air and the Ideal Gas Law
In a perfect or ideal gas the correlations between pressure, volume, temperature and quantity of gas can be expressed by the Ideal Gas Law.
The Universal Gas Constant,Ru is independent of the particular gas and is the same for all "perfect" gases, and is included in of The Ideal Gas Law:
p V = n Ru T (1)
p = absolute pressure (N/m2, lb/ft2)
V = volume (m3, ft3)
n = is the number of moles of the gas present
Ru = universal gas constant (J/mol K, lbf ft/(lb moloR) = 8.3145 J/mol K = 0.08206 L atm/mol K = 62.37 torr /mol K
T = absolute temperature (K, oR)
For a given quantity of gas, both n and Ru are constant, and Equation (1) can be modified to
p1 V1 / T1 = p2V2 / T2 (2)
expressing the relationship between different states for the given quantity of the gas.
Equation (1) can also be expressed as
p V = N k T (3)
N =number of molecules
k = Boltzmann constant = 1.38066×10-23 J/K = 8.617385×10-5 eV/K
- One mole of an ideal gas at STP occupies 22.4 liters.
The Ideal Gas Law express the relation between pressure, temperature and volume in an ideal or perfect gas.
The Ideal Gas Law expessed by the Induvidual Gas Constant
The Ideal Gas Law can be expressed with the Individual Gas Constant as
p V = m R T (4)
V = volume of gas (m3, ft3)
m = mass of gas (kg, slugs)
R = individual gas constant (J/kg K, ft lb/slugsoR)
T = absolute temperature (K,oR)
Density can be expressed as
ρ = m / V (4b)
ρ = density (kg/m3, slugs/ft3)
and equation (4) can be modified to
p = ρ R T (4c)
The Individual and Universal Gas Constant
The Individual Gas Constant can be expressed with the Universal Gas Constant and the molecular weight of a gas like
R = Ru / Mgas (5)
Mgas = molecular weight of the gas
Ru = universal gas constant ( 8314.47 J/(kmol K))
The Molecular weight and the Individual Gas Constants for air and water vapor are listed below:
Gas | Individual Gas Constant - R | Molecular Weight (kg/kmole) | |
Imperial Units (ft lb/slug oR) | SI Units (J/kg K) | ||
Air | 1716 | 286.9 | 28.97 |
Water vapor | 2760 | 461.4 | 18.02 |
Air Pressure
Daltons Law states that
- the total pressure exerted by a mixture of gases is the sum of the partial pressures of the individual gases
The total pressure in moist air can therefore be expressed as
pt = pa + pw (6)
pt = total pressure (kPa)
pa = partial pressure dry air (kPa)
pw = partial pressure water vapor (kPa)
Dry Air Partial Pressure
Dry air partial pressure can be expressed as
pa = ρa (286.9 J/kg K) T (7)
Water Vapor Partial Pressure
The water vapor partial pressure can be expressed as
pw = ρw (461.5 J/kg K) T (7b)
Unlike other gases in air, water vapor may condense under common conditions. Since the boiling point of water at normal atmospheric pressure (101.3 kPa) is 100 oC, the vapor partial pressure of water is low compared to dry air partial pressure in moist air. Common values for vapor pressure in moist air are in the range 0.5 to 3.0 kPa .
Maximum vapor pressure before water vapor start to condense at an actual temperature is called saturation pressure - pws .
• Air Psychrometrics
• Basics
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Individual & Universal Gas Constants: Definitions, Values, and Applications
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Specific vs. Relative Humidity
Specific humidity of moist air vs. relative humidity, water vapor and air density.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Nitrogen - Enthalpy, Internal Energy and Entropy vs. Temperature
Enthalpy, internal energy and entropy of Nitrogen as an ideal gas.
The Ideal Gas Law
