Density and specific volume of dry air and water vapor at temperatures ranging 225 to 900 oF (107 to 482oC) are indicated below.
Values are for atmospheric pressure - 29.96 inches Mercury (760 mm Mercury, 14.696 psia, 1.0333 kg/cm2, 101.33 kPa).
Temperature | Dry Air | Water Vapor | |||
(oF) | (oC) | Specific Volume (ft3/lb) | Density (lb/ft3) | Specific Volume (ft3/lb) | Density (lb/ft3) |
225 | 107 | 17.2 | 0.0581 | 27.7 | 0.0361 |
250 | 121 | 17.8 | 0.0562 | 28.7 | 0.0349 |
275 | 135 | 18.5 | 0.0541 | 29.7 | 0.0337 |
300 | 149 | 19.1 | 0.0524 | 30.8 | 0.0325 |
325 | 163 | 19.7 | 0.0508 | 31.8 | 0.0314 |
350 | 177 | 20.3 | 0.0493 | 32.7 | 0.0306 |
375 | 191 | 21.0 | 0.0476 | 33.8 | 0.0296 |
400 | 204 | 21.6 | 0.0463 | 34.8 | 0.0287 |
450 | 232 | 22.8 | 0.0439 | 36.8 | 0.0272 |
500 | 260 | 24.1 | 0.0415 | 38.8 | 0.0258 |
600 | 316 | 26.6 | 0.0376 | 42.9 | 0.0233 |
700 | 371 | 29.1 | 0.0344 | 46.9 | 0.0213 |
800 | 427 | 31.6 | 0.0316 | 21.0 | 0.0196 |
900 | 482 | 34.1 | 0.0293 | 55.0 | 0.0182 |
- T (oF) = (T (oC)) (9/5) + 32
- 1 ft3/lbm = 1728 in3/lbm = 7.48 U.S. gal/lbm = 62.43 liter/kg = 0.062 m3/kg
- 1 lb/ft3 = 16.018 kg/m3 = 0.016 g/cm3
• Air Psychrometrics
• Densities
Density and specific volume of air varies with elevation above sea level.
Air Properties: Temperature, Pressure & Density Data
Density Converter
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
