U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
A "Standard Atmosphere" can be regarded as an average pressure, temperature and air density for various altitudes.
The "U.S. Standard Atmosphere 1976" is an atmospheric model of how the pressure, temperature, density, and viscosity of the Earth's atmosphere changes with altitude. It is defined as having a temperature of 288.15 K (15 oC, 59 oF) at the sea level 0 km geometrical height and 101325 Pa (1013.25 hPa, 1013.25 mbar, 760 mm Hg, 29.92 in Hg).
Geometrical altitude is the scale of elevation we would measure with a tape measure. Geopotential altitude is based on a scale that relates altitude to gravitational equipotentials, or surfaces of constant gravitational potential energy per unit mass.
The atmosphere are divided in
- the Troposphere - ranging 0 to 11 km (36.000 ft) altitude
- the Stratosphere - ranging 11 to to 51 km (167.000 ft) altitude
- the Mesosphere - ranging 51 to 71 km (232.000 ft) altitude
- the Ionosphere - ranging above 71 km (above 232.000 ft) altitude
U.S. Standard Atmosphere Air Properties - Imperial (BG) Units
| Geo-potential Altitude above Sea Level - h - (ft) | Temperature - t - (oF) | Acceleration of Gravity - g - (ft/s2) | Absolute Pressure - p - (lb/in2) | Density - ρ - (10-4 slugs/ft3) | Dynamic Viscosity - μ - (10-7 lb s/ft2) (10-7 slug /(ft s)) |
| -5000 | 76.84 | 32.189 | 17.554 | 27.45 | 3.836 |
| 0 | 59 | 32.174 | 14.696 | 23.77 | 3.737 |
| 5000 | 41.17 | 32.159 | 12.228 | 20.48 | 3.637 |
| 10000 | 23.36 | 32.143 | 10.108 | 17.56 | 3.534 |
| 15000 | 5.55 | 32.128 | 8.297 | 14.96 | 3.430 |
| 20000 | -12.26 | 32.112 | 6.759 | 12.67 | 3.324 |
| 25000 | -30.05 | 32.097 | 5.461 | 10.66 | 3.217 |
| 30000 | -47.83 | 32.082 | 4.373 | 8.91 | 3.107 |
| 35000 | -65.61 | 32.066 | 3.468 | 7.38 | 2.995 |
| 40000 | -69.70 | 32.051 | 2.730 | 5.87 | 2.969 |
| 45000 | -69.70 | 32.036 | 2.149 | 4.62 | 2.969 |
| 50000 | -69.70 | 32.020 | 1.692 | 3.64 | 2.969 |
| 60000 | -69.70 | 31.990 | 1.049 | 2.26 | 2.969 |
| 70000 | -67.42 | 31.959 | 0.651 | 1.39 | 2.984 |
| 80000 | -61.98 | 31.929 | 0.406 | 0.86 | 3.018 |
| 90000 | -56.54 | 31.897 | 0.255 | 0.56 | 3.052 |
| 100000 | -51.10 | 31.868 | 0.162 | 0.33 | 3.087 |
| 150000 | 19.40 | 31.717 | 0.020 | 0.037 | 3.511 |
| 200000 | -19.78 | 31.566 | 0.003 | 0.0053 | 3.279 |
| 250000 | -88.77 | 31.415 | 0.000 | 0.00065 | 2.846 |
U.S. Standard Atmosphere Air Properties - Metric Units
| Geo potential Altitude above Sea Level - h - (m) | Temperature - t - (oC) | Acceleration of Gravity - g - (m/s2) | Absolute Pressure - p - (104 N/m2) | Density - ρ - (kg/m3) | Dynamic Viscosity - μ - (10-5 N s/m2) |
| -1000 | 21.50 | 9.810 | 11.39 | 1.347 | 1.821 |
| 0 | 15.00 | 9.807 | 10.13 | 1.225 | 1.789 |
| 1000 | 8.50 | 9.804 | 8.988 | 1.112 | 1.758 |
| 2000 | 2.00 | 9.801 | 7.950 | 1.007 | 1.726 |
| 3000 | -4.49 | 9.797 | 7.012 | 0.9093 | 1.694 |
| 4000 | -10.98 | 9.794 | 6.166 | 0.8194 | 1.661 |
| 5000 | -17.47 | 9.791 | 5.405 | 0.7364 | 1.628 |
| 6000 | -23.96 | 9.788 | 4.722 | 0.6601 | 1.595 |
| 7000 | -30.45 | 9.785 | 4.111 | 0.5900 | 1.561 |
| 8000 | -36.94 | 9.782 | 3.565 | 0.5258 | 1.527 |
| 9000 | -43.42 | 9.779 | 3.080 | 0.4671 | 1.493 |
| 10000 | -49.90 | 9.776 | 2.650 | 0.4135 | 1.458 |
| 15000 | -56.50 | 9.761 | 1.211 | 0.1948 | 1.422 |
| 20000 | -56.50 | 9.745 | 0.5529 | 0.08891 | 1.422 |
| 25000 | -51.60 | 9.730 | 0.2549 | 0.04008 | 1.448 |
| 30000 | -46.64 | 9.715 | 0.1197 | 0.01841 | 1.475 |
| 40000 | -22.80 | 9.684 | 0.0287 | 0.003996 | 1.601 |
| 50000 | -2.5 | 9.654 | 0.007978 | 0.001027 | 1.704 |
| 60000 | -26.13 | 9.624 | 0.002196 | 0.0003097 | 1.584 |
| 70000 | -53.57 | 9.594 | 0.00052 | 0.00008283 | 1.438 |
| 80000 | -74.51 | 9.564 | 0.00011 | 0.00001846 | 1.321 |
US Atmosphere - Temperature vs. Elevation
Density and specific volume of air varies with elevation above sea level.
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Atmospheric Pressure vs. Elevation above Sea Level
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa.
Barometer - Altitude Compensation
Elevation compensating manometer.
Barometric Pressure - Pressure in psi, psf and kPa
Convert between barometric pressure inches Hg, psi and psf.
International Standard Atmosphere
International standard atmosphere in elevation -2000 to 30000 metre - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound.
Pressure
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
