Standard values for pressure, temperature and density (ignoring the slight effect of humidity) at altitudes from sea level to 16,000 feet (about 4900 m):
Altitude (feet) | Abs. Pressure (in. Hg) | Temp. (F) | Density (%) |
sea level | 29.92 | 59.0 | 100 |
2000 | 27.82 | 51.9 | 94.3 |
4000 | 25.84 | 44.7 | 88.8 |
6000 | 23.98 | 37.6 | 83.6 |
8000 | 22.22 | 30.5 | 78.6 |
10000 | 20.57 | 23.3 | 73.8 |
12000 | 19.02 | 16.2 | 69.3 |
14000 | 17.57 | 9.1 | 65.0 |
16000 | 16.21 | 1.9 | 60.9 |
- density - % of density at sea level
- 1 ft (foot) = 0.3048 m
- 1 in mercury (Hg) = 3,376.8 N/m2 (Pa)= 0.49 lb/in2 (psi) = 12.8 in water
- T (oC) = 5/9 (T (oF) - 32)
Density and specific volume of air varies with elevation above sea level.
Air - SCFM versus ACFM and ICFM
Actual air compressor capacity (ACFM) vs. standard air capacity (SCFM) and inlet air capacity (ICFM).
Air - Volume vs. Temperature
Air volume vs. temperature correction factor compared to Normal Air Conditions.
Atmospheric Pressure vs. Elevation above Sea Level
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa.
Barometer - Altitude Compensation
Elevation compensating manometer.
International Standard Atmosphere
International standard atmosphere in elevation -2000 to 30000 metre - pressure, temperature, density, viscosity, thermal conductivity and velocity of sound.
Speed of Sound vs. Elevation, Temperature and Air Pressure
Altitude and speed of sound, temperature and pressure.
U.S. Standard Atmosphere: Temperature, Pressure, and Air Properties vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude.
Water - Boiling Points vs. Altitude
Elevation above sea level and the boiling point of water.
