Moist Air - Specific vs. Relative Humidity
Humidity is the quantity of water vapor present in air. It can be expressed as an absolute, specific or a relative value.
If we know the relative humidity of the moist air and the water vapor density and the density of the air, the specific humidity can be expressed as:
x = 0.622 φ ρws / (ρ - ρws) 100% (1)
x = specific humidity (humidity ratio) of air vapor mixture (kgh2o/kgdry_air)
φ = relative humidity (%)
ρws = density of water vapor (kg/m3)
ρ = density of the moist or humid air (kg/m3)
• Air Psychrometrics
Air - Absolute Humidity
Absolute humidity is the actual mass of water vapor present in the air water vapor mixture.
Air - Humidity Ratio
Humid Air vs. the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Mixing of Humid Air
Moist Air - Enthalpy
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Recommended Relative Humidity
Recommended relative humidity level.
