Using steam to humidify air.
The optimum relative humidity ranges for bacteria, viruses, fungi, mites, asthma.
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Specific humidity of moist air vs. relative humidity, water vapor and air density.
Recommended relative humidity level.
Recommended relative humidity in production and process environments - like libraries, breweries, storages and more.
