The amount of vapor in 100 m3 air volume is indicated below.
Dry Bulb Temperature (oC) | Vapor in Air (kg per 100 m3air) | ||||||||||||
Relative Humidity (%) | |||||||||||||
100 | 85 | 80 | 75 | 70 | 65 | 60 | 55 | 50 | 45 | 40 | 35 | 30 | |
32 | 3.39 | 2.89 | 2.72 | 2.55 | 2.38 | 2.19 | 2.04 | 1.93 | 1.7 | 1.53 | 1.36 | 1.19 | 1.02 |
31 | 3.22 | 2.73 | 2.57 | 2.41 | 2.25 | 2.1 | 1.93 | 1.77 | 1.61 | 1.45 | 1.29 | 1.13 | 0.97 |
30 | 3.05 | 2.59 | 2.44 | 2.29 | 2.13 | 1.97 | 1.83 | 1.67 | 1.52 | 1.37 | 1.22 | 1.07 | 0.91 |
29 | 2.89 | 2.45 | 2.31 | 2.17 | 2.02 | 1.88 | 1.73 | 1.59 | 1.45 | 1.3 | 1.16 | 1.01 | 0.87 |
28 | 2.73 | 2.32 | 2.19 | 2.05 | 1.91 | 1.78 | 1.64 | 1.5 | 1.37 | 1.23 | 1.1 | 0.96 | 0.82 |
27 | 2.59 | 2.2 | 2.07 | 1.94 | 1.81 | 1.68 | 1.55 | 1.42 | 1.29 | 1.16 | 1.03 | 0.91 | 0.78 |
26 | 2.45 | 2.08 | 1.96 | 1.83 | 1.71 | 1.59 | 1.47 | 1.34 | 1.22 | 1.1 | 0.97 | 0.86 | 0.73 |
25 | 2.31 | 1.97 | 1.85 | 1.73 | 1.62 | 1.5 | 1.39 | 1.27 | 1.16 | 1.04 | 0.93 | 0.81 | 0.69 |
24 | 2.19 | 1.86 | 1.75 | 1.64 | 1.53 | 1.42 | 1.31 | 1.2 | 1.09 | 0.98 | 0.87 | 0.77 | 0.66 |
23 | 2.06 | 1.76 | 1.63 | 1.55 | 1.45 | 1.34 | 1.24 | 1.14 | 1.03 | 0.93 | 0.83 | 0.72 | 0.62 |
22 | 1.95 | 1.66 | 1.56 | 1.46 | 1.36 | 1.27 | 1.17 | 1.07 | 0.98 | 0.88 | 0.78 | 0.68 | 0.59 |
21 | 1.84 | 1.56 | 1.47 | 1.38 | 1.29 | 1.2 | 1.1 | 1.02 | 0.92 | 0.83 | 0.74 | 0.67 | 0.55 |
20 | 1.74 | 1.48 | 1.39 | 1.3 | 1.22 | 1.13 | 1.04 | 0.98 | 0.87 | 0.78 | 0.69 | 0.61 | 0.52 |
19 | 1.63 | 1.39 | 1.31 | 1.23 | 1.15 | 1.06 | 0.98 | 0.9 | 0.82 | 0.74 | 0.65 | 0.57 | 0.49 |
18 | 1.54 | 1.31 | 1.24 | 1.16 | 1.08 | 1 | 0.93 | 0.85 | 0.77 | 0.69 | 0.62 | 0.54 | 0.46 |
17 | 1.45 | 1.24 | 1.16 | 1.09 | 1.02 | 0.94 | 0.87 | 0.8 | 0.73 | 0.65 | 0.59 | 0.51 | 0.44 |
15 | 1.29 | 1.1 | 1.03 | 0.97 | 0.9 | 0.84 | 0.77 | 0.71 | 0.66 | 0.58 | 0.52 | 0.45 | 0.39 |
10 | 0.94 | 0.8 | 0.76 | 0.71 | 0.66 | 0.61 | 0.57 | 0.52 | 0.47 | 0.43 | 0.38 | 0.33 | 0.28 |
0 | 0.49 | 0.41 | 0.39 | 0.37 | 0.34 | 0.32 | 0.29 | 0.27 | 0.24 | 0.22 | 0.2 | 0.17 | 0.15 |
-5 | 0.33 | 0.28 | 0.26 | 0.25 | 0.23 | 0.21 | 0.2 | 0.18 | 0.16 | 0.15 | 0.13 | 0.11 | 0.1 |
-10 | 0.22 | 0.18 | 0.17 | 0.16 | 0.15 | 0.14 | 0.13 | 0.12 | 0.11 | 0.1 | 0.09 | 0.08 | 0.06 |
Note! In a psychrometric chart or in a Mollier diagram the amount of vapor humidity ratio - x - is indicated in kg/kgdry air (kg vapor per kg dry air). The values above can be transformed to kg/kgdry air by dividing the values with the air density at the actual temperature.
Example - Humidifying Air with Steam
Air at 20oC and 30% relative humidity are humidified to 20oC and 80% relative humidity.
From the table above it can be estimated that air at 20oC and 30% relative humidity contains 0.52 kg water vapor per 100 m3 air volume. Air at 20oC and 80% relative humidity contains 1.39 kg per 100 m3 air volume.
The amount of water vapor required per 100 m3 air volume can be calculated like
Amount of Water Vapor = (1.39 kg/100 m3 air volume) - (0.52 kg/100 m3 air volume)
= 0.87 (kg/100 m3 air volume)
• Air Conditioning
• Air Psychrometrics
• HVAC Systems
Heating, ventilation and air conditioning systems - design and dimensions.
• Steam and Condensate
• Thermodynamics
Thermodynamics of steam and condensate systems.
Air - Absolute Humidity
Absolute humidity is the actual mass of water vapor present in the air water vapor mixture.
Basic air changing state processes - heating, cooling, mixing, humidifying and dehumidifying by adding steam or water - psychometric diagrams and the Mollier charts.
Air - Humidity Ratio
Air - Psychrometric Chart for Standard Atmospheric Conditions - Imperial Units
Psychrometric chart for air at barometric pressure 29.921 inches of Mercury and temperature ranging 20oF to 120oF.
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Cooling and Heating Equations
Humid Air - Heating
Humidifiers
Sprayed coils, spinning discs and steam humidifiers.
Mixing of Humid Air
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Enthalpy
Steam Heating Air
