Humidifiers
Humidifying (increasing moisture) of ventilation systems air can be done with
  • sprayed coils
  • spinning discs
  • steam humidifiers
Warning! The water-borne bacteria causing the legionnaires disease 1) (legionella) may develop in humidifying water systems. The bacteria may be transferred to humans by the circulating air. Note that proper water treatment with chlorine dioxide or similar products to avoid the danger is vital!
Sprayed coils
In a sprayed coil unit water is discharged through high pressure nozzles into the air stream on to a finned coil. The coil provides additional surface where the water can evaporate into the air. The coil may also be heated to increase the evaporation.
Water droplets not evaporated are collected by filter plates downstream. Excess water is collected at the base and circulated to the high pressures nozzles by a pump.
The air velocity through a humidifying unit of this type is approximately 2 - 3.5 m/s .
Spinning discs
In a spinning disc water flows as a fine film over the surface of a rapidly revolving vertical disc. Water is thrown of the disc by centrifugal action onto a toothed ring and broken up into fine particles evaporating in the air flow.
Humidifying with Water - the Psychrometric Chart
When water is added and evaporated by the heat in the air - the process will follow the constant enthalpy line - approaching the saturation line.
Humidifying with Water - the Mollier Diagram
Steam humidifiers
In a steam humidifier a hot water generator delivers low pressure steam to a perforated distribution tube inserted into the air flow.
Since the water is boiled and not "reused", the risk for transferring water born bacteria - as legionella - to the air is minimal.
1) Legionnaires' disease is a lung infection (pneumonia) caused by a bacterium named Legionella pneumophila . The name Legionella pneumophila was derived from the original outbreak at the 1976 American Legion Convention in Philadelphia.
When steam is added to the air - enthalpy increases - and depending on the temperature and amount of the steam and - the process follows a direction as indicated in the diagrams below. When adding saturated steam at atmospheric pressure the temperature rise is very small - in general less than 1 o C ( 1 o F ) . For practical purposes the process of adding saturated steam at atmospheric pressure approximates the horizontal temperature line in the Mollier diagram and vertical line in the psychrometric chart.
Humidifying with Steam - the Psychrometric Chart
Humidifying with Steam - the Mollier Diagram
Ventilation
Using steam to humidify air.
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Cooling Tower Efficiency
Maximum cooling tower efficiency is limited by the cooling air wet-bulb temperature.
Evaporative Cooling
Evaporative cooling tutorial.
Legionella
The Legionella Pneumophila bacterium thrives in water supply systems and air conditioning systems - and may cause the Legionnairs disease.
