Great Sensible Heat Factor - GSHF
A cooling coil should have the capacity to handle the heat load generated in the room in addition the capacity to cool down the fresh make up air. The Great Sensible Factor is independent of the total air flow and can be expressed as
GSHF = (Qs + mf cp (tf - tr)) / (Qt + mf (hf - hr)) (1)
GSHF = Great Sensible Heat Factor
Qs = sensible heat generated in the room (kW)
mf = fresh air mass flow (make up air) (kg/s)
cp = specific heat of air (kg/kgoC)
tf = temperature in fresh air (oC)
tr = temperature in room air (oC)
Qt = total heat generated in the room (kW)
hf = specific enthalpy of fresh air (kJ/kgoC)
hr = specific enthalpy of air in the room (kJ/kgoC)
Example - Great Sensible Heat Factor - GSHF
The sensible heat generation in a room is 4 kW and the latent heat generated is 1.4 kW. The room is cooled with an air flow of 1000 kg/h.
The fresh (out door) air temperature is 28 oC with a specific enthalpy of 60 kJ/kg and a humidity ratio of 12.7 g/kg.
The room temperature is 22 oC with a specific enthalpy of 45 kJ/kg and a specific humidity of 9.1 g/kg.
The Great Sensible Heat Factor can be calculated like
GSHF = ((4000 W) + (1000 kg/h)(1/3600 s/h)(1000 J/kgoC)(28 oC - 22 oC)) / ((4000 W + 1400 W) + (1000 kg/h)(1/3600 s/h)(60000 J/kg - 45000 J/kg))
= 0.59
• Air Psychrometrics
Air - Humidity Ratio
Cooling and Heating Equations
Cooling Load - Latent and Sensible Heat
Latent and sensible cooling loads to consider when designing HVAC systems.
Humid Air - Heating
Latent Heat Flow
Metabolic Heat Gain from Persons
Human metabolic heat gain in air conditioned rooms.
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Enthalpy
Room Sensible Heat Factor - RSHF
Room Sensible Heat Factor - RSHF - is defined as the sensible heat load divided by the total heat load in a room
Sensible Heat Flow
Sensible heat is dry heat causing change in temperature but not in moisture content
Sensible Heat Ratio - SHR
The ratio Sensible Heat (or Cooling) Load to the Total Heat (or Cooling) Load.
