Critical temperature of air: 132.63 K = -140.52 °C = -220.94 °F
Critical pressure of air: 37.363 atm = 37.858 bar = 3.7858 MPa (MN/m 2 ) = 549.08 psi (=lb f /in 2 )
Triple point: The temperature and pressure at which the three phases (gas, liquid, and solid) of a substance coexist in thermodynamic equilibrium
Triple point pressure of air: 0.05196 atm = 0.05265 bar = 5265 Pa = 0.7636 psi (=lb f /in 2 )
Triple point temperature of air: 59.75 K = -213.40 °C = -352.12 °F
The figures below show the changes in thermophysical properties along the air boiling and condensation curves: Vapour pressure , density , viscosity , heat capacity , thermal conductivity .
Tabulated values given in SI and imperial units, and unit converters are given below the figures.
See also properties of Air at varying temperature and pressure: Density and specific weight at varying temperature , Density at varying pressure , Diffusion Coefficients for Gases in Air , Prandtl Number , Specific heat at varying temperature and Specific heat at varying pressure , Thermal Conductivity , Thermal Diffusivity , and Air thermophysical properties at standard conditions and Composition and molecular weight ,
Phase diagram of air:
The following figures show how the properties of air changes along the boiling and condensation curves (shown in the figure above) - SI units:
Properties of air along the boiling and condensation curves - SI units:
For full table with thermal conductivity, dynamic and kinematic viscosity - rotate the screen!
Temperature | Pressure | Density | Heat capacity C V | Heat capacity C P | Thermal conductivity | Dynamic Viscosity | Kinematic viscosity | ||
[K] | [°C] | [bara] | [g/l], [kg/m 3 ] | [kJ/kg K] | [kJ/kg K] | [mW/m K] | [kcal(IT)/(h m K)] | [μPa s] | [cSt], [m 2 /s*10 -6 ] |
Liquid | |||||||||
59.75 | -213.40 | 0.05265 | 957.6 | 1.174 | 1.901 | 171.4 | 0.1474 | 376.6 | 0.3933 |
65 | -208.2 | 0.1432 | 935.9 | 1.118 | 1.902 | 162.9 | 0.1401 | 292.4 | 0.3124 |
70 | -203.2 | 0.31908 | 914.6 | 1.102 | 1.908 | 154.7 | 0.1330 | 234.8 | 0.2567 |
75 | -198.2 | 0.63326 | 892.7 | 1.072 | 1.919 | 146.5 | 0.1260 | 192.4 | 0.2155 |
80 | -193.2 | 1.1462 | 870.2 | 1.045 | 1.938 | 138.2 | 0.1188 | 160.4 | 0.1843 |
85 | -188.2 | 1.9262 | 846.7 | 1.020 | 1.964 | 129.8 | 0.1116 | 135.8 | 0.1604 |
90 | -183.2 | 3.0475 | 822.2 | 0.9981 | 2.003 | 121.4 | 0.1044 | 116.4 | 0.1415 |
95 | -178.2 | 4.5886 | 796.2 | 0.9786 | 2.056 | 112.9 | 0.09709 | 100.7 | 0.1264 |
100 | -173.2 | 6.6313 | 768.5 | 0.9617 | 2.130 | 104.4 | 0.08978 | 87.61 | 0.1140 |
105 | -168.2 | 9.2606 | 738.6 | 0.9477 | 2.236 | 95.93 | 0.08249 | 76.41 | 0.1035 |
110 | -163.2 | 12.564 | 705.6 | 0.9373 | 2.389 | 87.55 | 0.07528 | 66.54 | 0.0943 |
115 | -158.2 | 16.633 | 668.5 | 0.9314 | 2.628 | 79.34 | 0.06822 | 57.57 | 0.0861 |
120 | -153.2 | 21.557 | 625.3 | 0.9325 | 3.048 | 71.36 | 0.06136 | 49.13 | 0.0786 |
125 | -148.2 | 27.427 | 571.4 | 0.9473 | 4.001 | 63.66 | 0.05474 | 40.76 | 0.0713 |
130 | -143.2 | 34.295 | 488.4 | 1.010 | 8.846 | 58.05 | 0.04992 | 31.07 | 0.0636 |
132.63 | -140.52 | 37.858 | 302.6 | 17.83 | 0.0589 | ||||
Gas | |||||||||
59.75 | -213.40 | 0.02432 | 0.1421 | 0.7183 | 1.009 | 5.294 | 0.004552 | 4.220 | 29.69 |
65 | -208.2 | 0.07756 | 0.4182 | 0.7219 | 1.017 | 5.844 | 0.005025 | 4.606 | 11.01 |
70 | -203.2 | 0.19431 | 0.9787 | 0.7275 | 1.030 | 6.376 | 0.005482 | 4.970 | 5.078 |
75 | -198.2 | 0.42282 | 2.006 | 0.7354 | 1.050 | 6.920 | 0.005950 | 5.333 | 2.658 |
80 | -193.2 | 0.82321 | 3.711 | 0.7459 | 1.078 | 7.485 | 0.006436 | 5.694 | 1.534 |
85 | -188.2 | 1.4665 | 6.336 | 0.7589 | 1.116 | 8.082 | 0.006949 | 6.057 | 0.9560 |
90 | -183.2 | 2.4320 | 10.16 | 0.7746 | 1.166 | 8.725 | 0.007502 | 6.427 | 0.6327 |
95 | -178.2 | 3.8047 | 15.50 | 0.7928 | 1.232 | 9.439 | 0.008116 | 6.810 | 0.4393 |
100 | -173.2 | 5.6742 | 22.77 | 0.8137 | 1.320 | 10.26 | 0.008819 | 7.215 | 0.3169 |
105 | -168.2 | 8.1341 | 32.49 | 0.8375 | 1.440 | 11.24 | 0.009662 | 7.659 | 0.2357 |
110 | -163.2 | 11.282 | 45.42 | 0.8651 | 1.614 | 12.47 | 0.01072 | 8.163 | 0.1797 |
115 | -158.2 | 15.223 | 62.75 | 0.8981 | 1.887 | 14.15 | 0.01216 | 8.770 | 0.1398 |
120 | -153.2 | 20.067 | 86.57 | 0.9399 | 2.373 | 16.64 | 0.01430 | 9.552 | 0.1103 |
125 | -148.2 | 25.949 | 121.5 | 0.9981 | 3.474 | 20.97 | 0.01803 | 10.68 | 0.0879 |
130 | -143.2 | 33.084 | 182.7 | 1.095 | 8.031 | 31.81 | 0.02735 | 12.78 | 0.0699 |
Properties of air along the boiling and condensation curves - Imperial units:
Temperature | Pressure | Density | Heat capacity C V | Heat capacity C P | Thermal conductivity | Dynamic viscosity | Kinematic viscosity | |||
[K] | [°F] | [psia] | [lb/ft 3 ] | [sl/ft 3 ] | [Btu(IT)/lb °F] | [Btu(IT)/lb °F] | [Btu(IT)/(h ft °F)] | [lb f s/ft2 *10-6] | [lb m /ft s*10 -6 ] | [ft 2 /s*10 -6 ] |
Liquid | ||||||||||
59.75 | -352.12 | 0.76363 | 59.79 | 1.858 | 0.2805 | 0.4541 | 0.09905 | 7.866 | 253.1 | 4.233 |
65 | -343.7 | 2.077 | 58.43 | 1.816 | 0.2671 | 0.4543 | 0.09413 | 6.107 | 196.5 | 3.363 |
70 | -334.7 | 4.6279 | 57.10 | 1.775 | 0.2632 | 0.4557 | 0.08940 | 4.904 | 157.8 | 2.763 |
75 | -325.7 | 9.1847 | 55.73 | 1.732 | 0.2560 | 0.4584 | 0.08464 | 4.017 | 129.3 | 2.319 |
80 | -316.7 | 16.624 | 54.32 | 1.688 | 0.2495 | 0.4628 | 0.07982 | 3.350 | 107.8 | 1.984 |
85 | -307.7 | 27.937 | 52.86 | 1.643 | 0.2437 | 0.4692 | 0.07499 | 2.836 | 91.24 | 1.726 |
90 | -298.7 | 44.200 | 51.33 | 1.595 | 0.2384 | 0.4783 | 0.07013 | 2.431 | 78.20 | 1.524 |
95 | -289.7 | 66.552 | 49.71 | 1.545 | 0.2337 | 0.4911 | 0.06524 | 2.103 | 67.65 | 1.361 |
100 | -280.7 | 96.179 | 47.98 | 1.491 | 0.2297 | 0.5088 | 0.06033 | 1.830 | 58.87 | 1.227 |
105 | -271.7 | 134.31 | 46.11 | 1.433 | 0.2264 | 0.5339 | 0.05543 | 1.596 | 51.35 | 1.114 |
110 | -262.7 | 182.23 | 44.05 | 1.369 | 0.2239 | 0.5707 | 0.05059 | 1.390 | 44.71 | 1.015 |
115 | -253.7 | 241.24 | 41.73 | 1.297 | 0.2225 | 0.6278 | 0.04584 | 1.202 | 38.69 | 0.927 |
120 | -244.7 | 312.66 | 39.04 | 1.213 | 0.2227 | 0.7279 | 0.04123 | 1.026 | 33.01 | 0.846 |
125 | -235.7 | 397.80 | 35.67 | 1.109 | 0.2263 | 0.9556 | 0.03678 | 0.8512 | 27.39 | 0.768 |
130 | -226.7 | 497.41 | 30.49 | 0.9477 | 0.2411 | 2.113 | 0.03354 | 0.6490 | 20.88 | 0.685 |
132.63 | -220.94 | 549.08 | 18.89 | 0.5872 | 0.3724 | 11.98 | 0.634 | |||
Gas | ||||||||||
59.75 | -352.12 | 0.3527 | 0.00887 | 0.000276 | 0.1716 | 0.2409 | 0.003059 | 0.0881 | 2.836 | 319.562 |
65 | -342.7 | 1.1249 | 0.02611 | 0.000811 | 0.1724 | 0.2429 | 0.003377 | 0.0962 | 3.095 | 118.544 |
70 | -333.7 | 2.8182 | 0.06110 | 0.001899 | 0.1738 | 0.2460 | 0.003684 | 0.1038 | 3.340 | 54.663 |
75 | -324.7 | 6.1325 | 0.1253 | 0.003893 | 0.1757 | 0.2508 | 0.003998 | 0.1114 | 3.583 | 28.608 |
80 | -315.7 | 11.940 | 0.2317 | 0.00720 | 0.1782 | 0.2574 | 0.004325 | 0.1189 | 3.826 | 16.514 |
85 | -306.7 | 21.270 | 0.3956 | 0.01229 | 0.1813 | 0.2665 | 0.004670 | 0.1265 | 4.070 | 10.290 |
90 | -297.7 | 35.273 | 0.6341 | 0.01971 | 0.1850 | 0.2785 | 0.005041 | 0.1342 | 4.319 | 6.811 |
95 | -288.7 | 55.183 | 0.9677 | 0.03008 | 0.1894 | 0.2942 | 0.005454 | 0.1422 | 4.576 | 4.729 |
100 | -279.7 | 82.297 | 1.421 | 0.04418 | 0.1943 | 0.3152 | 0.005926 | 0.0119 | 0.381 | 3.411 |
105 | -270.7 | 117.98 | 2.028 | 0.06304 | 0.2000 | 0.3440 | 0.006493 | 0.1600 | 5.146 | 2.537 |
110 | -261.7 | 163.63 | 2.836 | 0.08814 | 0.2066 | 0.3855 | 0.007207 | 0.1705 | 5.486 | 1.934 |
115 | -252.7 | 220.79 | 3.917 | 0.1218 | 0.2145 | 0.4506 | 0.008173 | 0.1832 | 5.893 | 1.504 |
120 | -243.7 | 291.05 | 5.405 | 0.1680 | 0.2245 | 0.5668 | 0.009612 | 0.1995 | 6.419 | 1.188 |
125 | -234.7 | 376.36 | 7.583 | 0.2357 | 0.2384 | 0.8298 | 0.01212 | 0.2231 | 7.177 | 0.947 |
130 | -225.7 | 479.84 | 11.41 | 0.3545 | 0.2616 | 1.918 | 0.01838 | 0.2668 | 8.584 | 0.753 |
Density unit converter
Dynamic viscosity unit converter
Kinematic viscosity unit converter
Pressure unit converter
Specific heat (heat capacity) and entropy unit converter
Temperature unit converter
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units.
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more.
Water may condensate when air is cooled in air conditioning systems.
Pressure loss in compressed air pipe lines.
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Weight of water vapor in air
The amount of air that can be dissolved in water decreases with temperature and increases with pressure.
