Compressed air pipeline pressure drop in kg/m2 per 100 m pipe can be estimated for typical entering pressures in the diagrams below. The diagrams are calculated for schedule 40 pipes.
Other dimensions or pressures can be calculated with the
Compressed Air Entering Pressure 5 kg/cm2
  • 1 kg/cm2 = 0.98 bar = 735 mmHg = 10000 mmH2O = 14.2 psi
  • 1 m3/min = 0.017 m3/s = 60 m3/h = 1000 liter/min = 35.3 cfm
  • 1 m (meter) = 3.2808 ft = 39.37 in
Compressed Air Entering Pressure 7.5 kg/cm2
Compressed Air Entering Pressure 10 kg/cm2
Compressed Air Entering Pressure 13 kg/cm2
Compressed air pressure drop for pipes other than Schedule 40
Compressed air pressure drop in pipes other than schedule 40 can be calculated as
dp = dp40 (d40 / d)5                                                      (1)
dp = actual pressure drop (bar per 100 m pipe)
dp40 = pressure drop in schedule 40 pipe from the table or diagram above (bar per 100 m pipe)
d40 = inside diameter schedule 40 pipe (inches)
d = actual inside diameter (inches)
Gases and Compressed Air
Air - Prandtl Number
Air Properties: Temperature, Pressure & Density Data
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Compressed Air - Air Flow and Recommended Pipe Size
Pipe line sizing compressed air
Compressed Air - Friction Loss in Hoses
Friction loss in air hoses vs. operating pressure.
Compressed Air - Laboratory Consumption
Compressed air supply to laboratories.
Compressed Air - Pipe Line Pressure Loss - Online Calculator with Metric and Imperial Units
Calculate pressure drop in compressed air pipe lines - metric and imperial units.
Compressed Air - Size of Pipe vs. Capacity
Air pipe lines capacities at pressure 100 psi (6.9 bar).
Compressed Air Pipe Lines - Pressure Loss vs. Capacity and Operating Pressure
Pressure drop in compressed air pipe lines.
Compressed Air Piping - Pressure Loss Diagrams, Imperial Units
Pressure drop in compressed air pipelines with applied pressure 50, 100 and 150 psi.
Compressed Air vs. Free Air - Compression Ratio
The ratio of compressed air pressure to free air pressure.
